It is currently Mon Apr 06, 2026 4:18 pm
Reply to topic  [ 3 posts ]
 CAV PLATE MAYHEM
Post CAV PLATE MAYHEM
I just built three longtails with 13 hp engines and 8x4 props. I am yet to install cav plates. Does anybody have any input on what angle the cav plate should be in relation to the prop shaft? Also how big should the cav plate be? the motors will be run on 1448mv alumacrafts with a 15" transom.
Sun Oct 21, 2012 7:47 pm
Post Re: CAV PLATE MAYHEM
make the cav plate parralel with the motor mount plate and and slightly wider than the width of the prop you will use
Mon Oct 22, 2012 7:17 am
Thanks
Mon Oct 22, 2012 4:44 pm
cron
