It is currently Mon Apr 06, 2026 11:19 am
[ 4 posts ] |
Transom Too tall for new motor
Buck007
I have 648 war eagle with the 21" transom, from my reading online I have noticed a lot of guys complaining of poor performance out of their longtail motors with this height of transom. Well I just bought a 35hp beavertail with a 70" shaft. My question is two part.
1) Will the transom height adversely effect performance 2) What fixes are their aside from cutting my boat or buying new boat.
Thank you guys in advance for helping a newby, and yes I understand this has probably been covered, but I couldnt find it. Im 57 and new to message boards.
Thanks, Buck
| Thu Oct 25, 2012 5:25 pm |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
 Re: Transom Too tall for new motor
Welcome! More than likely you will see some performance issues but aside from that it'll run just maybe not to its full potential. Your options are pretty slim... I'd try the combo out first and see if it meets your expectations, if it doesn't I'd see what you might be able to change to make your setup better for your needs be its sell the motor and look for a tall transom model...(which MB might not make?) or look into a surface drive. you could also sell the boat and look at getting one that is a little larger? Let us know how it runs and what path you end up taking!
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Thu Oct 25, 2012 5:51 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
Try it out first, it may be fine. If not, having the transom cut down is an easy and inexpensive fix.
| Thu Oct 25, 2012 5:54 pm |
Buck007
Thanks guys. I really appreciate the info. I will give it a try and let you know how it goes. Thanks again, Buck
| Fri Oct 26, 2012 8:17 am |
[ 4 posts ] |
