It is currently Mon Apr 06, 2026 7:47 am
Reply to topic  [ 14 posts ]
 Boat mods?
Post Boat mods?
I have aluminum riveted 1437 with a 15.5" reinforced transom. Going to be running a 20hp long shaft beavertail.
What should I do to the boat or do I really need anything?
Handrail? Pods? Etc......
1844 GD with 35HP GDSD
Fri Nov 02, 2012 6:53 am
Post Re: Boat mods?
I'd beef up that trnasom cause mud motors are hell on transoms
Fri Nov 02, 2012 6:54 am
Post Re: Boat mods?
It's got a 3/4" piece of plywood bolted inside the lip that covers the entire transom......need more?
Fri Nov 02, 2012 7:13 am
Post Re: Boat mods?
I'm talking about welded aluminum braces from the floor to the tansom
Fri Nov 02, 2012 8:29 am
Post Re: Boat mods?
Oh...it has two of those already.
Do I really need a handrail? Seems like everyone else has one. Wasn't sure if that's a "nice to have" or a "need to have."
Fri Nov 02, 2012 8:33 am
Post Re: Boat mods?
You talking about a grab handle? I would suggest it, them mud motors can jerk you around when you get in the nasty stuff
Fri Nov 02, 2012 8:35 am
Post Re: Boat mods?
Now the next question......anyone know someone in SE Texas that can manufacture and weld one on for me for a relatively low price?
Fri Nov 02, 2012 8:42 am
Post Re: Boat mods?
sure do bring it to Watson's or borel boat works, there are a handful of aluminum wleders i just can't think of all of them
Fri Nov 02, 2012 11:15 am
Post Re: Boat mods?
Where are those located? I'm outside of Houston
Fri Nov 02, 2012 12:12 pm
Post Re: Boat mods?
hmmm i thought you were closer by the way you asked the question, if your in cypress they are about 1hour and 30 min. from you
Fri Nov 02, 2012 12:21 pm
Post Re: Boat mods?
I hunt and work all over SE Texas, so I don't mind a drive....
Fri Nov 02, 2012 12:48 pm
Post Re: Boat mods?
Watson is here in groves where i live, Borel is in orange Tx. which is about 25min from me, and iknow of some others
Fri Nov 02, 2012 9:28 pm
Post Re: Boat mods?
I bolted a piece of 3/8 aluminum about 30" wide and the same height as the transom and welded braces to the plate and then riveted the braces to the seat
23 swomp/ 1542 tracker
Sat Nov 03, 2012 4:32 am
Post Re: Boat mods?
The bracing is a good idea. I ran a rivetted 1436 w/18 HP GD LT for several years, and the 1/8" alum. U plate I slipped on the transom held up. Important standard equipment you should have: working kill switch w/lanyard (use it!), auto bilge (backup manual bilge pump), PFD's, running lights, flagpole and flag for visibility in the marsh, emergency lights and horn, flares, all necessary tools, spare fuses-fuel line-clamps-throttle-plugs-grease gun-prop.
Indicated mods: steelflex or gatorglide the hull bottom; tweak the throttle for a few hundred rpm gain; alum floor with closed cell flotation under floor and between ribs; hydroturf for surfaces; battery and/or gas tank placed in front; trollling motor bow/mount; DIY scissors blind for boat; synthetic oil and grease. Whew, that's a start. :mrgreen:
Sat Nov 03, 2012 5:09 am
