| Boat mods? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=33920 |
| Author: | Boudreaux76 [ Fri Nov 02, 2012 6:53 am ] |
| Post subject: | Boat mods? |
I have aluminum riveted 1437 with a 15.5" reinforced transom. Going to be running a 20hp long shaft beavertail. What should I do to the boat or do I really need anything? Handrail? Pods? Etc...... |
| Author: | take'emgator [ Fri Nov 02, 2012 6:54 am ] |
| Post subject: | Re: Boat mods? |
I'd beef up that trnasom cause mud motors are hell on transoms |
| Author: | Boudreaux76 [ Fri Nov 02, 2012 7:13 am ] |
It's got a 3/4" piece of plywood bolted inside the lip that covers the entire transom......need more? |
| Author: | take'emgator [ Fri Nov 02, 2012 8:29 am ] |
I'm talking about welded aluminum braces from the floor to the tansom |
| Author: | Boudreaux76 [ Fri Nov 02, 2012 8:33 am ] |
Oh...it has two of those already. Do I really need a handrail? Seems like everyone else has one. Wasn't sure if that's a "nice to have" or a "need to have." |
| Author: | take'emgator [ Fri Nov 02, 2012 8:35 am ] |
You talking about a grab handle? I would suggest it, them mud motors can jerk you around when you get in the nasty stuff |
| Author: | Boudreaux76 [ Fri Nov 02, 2012 8:42 am ] |
Now the next question......anyone know someone in SE Texas that can manufacture and weld one on for me for a relatively low price? |
| Author: | take'emgator [ Fri Nov 02, 2012 11:15 am ] |
sure do bring it to Watson's or borel boat works, there are a handful of aluminum wleders i just can't think of all of them |
| Author: | Boudreaux76 [ Fri Nov 02, 2012 12:12 pm ] |
Where are those located? I'm outside of Houston |
| Author: | take'emgator [ Fri Nov 02, 2012 12:21 pm ] |
hmmm i thought you were closer by the way you asked the question, if your in cypress they are about 1hour and 30 min. from you |
| Author: | Boudreaux76 [ Fri Nov 02, 2012 12:48 pm ] |
I hunt and work all over SE Texas, so I don't mind a drive.... |
| Author: | take'emgator [ Fri Nov 02, 2012 9:28 pm ] |
Watson is here in groves where i live, Borel is in orange Tx. which is about 25min from me, and iknow of some others |
| Author: | Trousertrout [ Sat Nov 03, 2012 4:32 am ] |
I bolted a piece of 3/8 aluminum about 30" wide and the same height as the transom and welded braces to the plate and then riveted the braces to the seat |
| Author: | Glades Ranger [ Sat Nov 03, 2012 5:09 am ] |
The bracing is a good idea. I ran a rivetted 1436 w/18 HP GD LT for several years, and the 1/8" alum. U plate I slipped on the transom held up. Important standard equipment you should have: working kill switch w/lanyard (use it!), auto bilge (backup manual bilge pump), PFD's, running lights, flagpole and flag for visibility in the marsh, emergency lights and horn, flares, all necessary tools, spare fuses-fuel line-clamps-throttle-plugs-grease gun-prop. Indicated mods: steelflex or gatorglide the hull bottom; tweak the throttle for a few hundred rpm gain; alum floor with closed cell flotation under floor and between ribs; hydroturf for surfaces; battery and/or gas tank placed in front; trollling motor bow/mount; DIY scissors blind for boat; synthetic oil and grease. Whew, that's a start. |
