It is currently Wed Apr 08, 2026 8:07 pm
Reply to topic  [ 7 posts ]
 Shaft prop nut creeping up to seal collar
Post Shaft prop nut creeping up to seal collar
Having a problem with nut between prop and seal collar creeping up to the collar. Any ideas how to keep it against the prop? BTW it's an OLD 8hp go-devil. When I got it not too long ago it was riding on the seal so I lowered the nuts prop etc. per go-devil cause it'll seize now it won't stay down
Sun Nov 18, 2012 4:24 pm
Post Re: Shaft prop nut creeping up to seal collar
Loosen shaft in upper u joint and slide it down. Then retighten everything.
Sun Nov 18, 2012 5:03 pm
If there is room on the threads to use two jam nuts in front of the prop? Take those two and crank 'em together on the shaft to act as a stop.
1436 Lowe
Sun Nov 18, 2012 7:14 pm
What I was saying is that the threads shouldn't be that close I the seal to begin with.
Sun Nov 18, 2012 7:21 pm
1436 Lowe
Sun Nov 18, 2012 7:25 pm
unless hes just using to soft of a nut then it would push through the threads on the nut
Sun Nov 18, 2012 7:46 pm
I'll try lowering the shaft cause the threads do go into the collar how far i don't know thanks.
Sun Nov 18, 2012 11:19 pm
