It is currently Fri Apr 03, 2026 2:11 am
[ 7 posts ] |
Shaft prop nut creeping up to seal collar
sdm111
Having a problem with nut between prop and seal collar creeping up to the collar. Any ideas how to keep it against the prop? BTW it's an OLD 8hp go-devil. When I got it not too long ago it was riding on the seal so I lowered the nuts prop etc. per go-devil cause it'll seize now it won't stay down
| Sun Nov 18, 2012 4:24 pm |
autogateman
 Re: Shaft prop nut creeping up to seal collar
Loosen shaft in upper u joint and slide it down. Then retighten everything.
| Sun Nov 18, 2012 5:03 pm |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
If there is room on the threads to use two jam nuts in front of the prop? Take those two and crank 'em together on the shaft to act as a stop.
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Sun Nov 18, 2012 7:14 pm |
autogateman
What I was saying is that the threads shouldn't be that close I the seal to begin with.
| Sun Nov 18, 2012 7:21 pm |
SwampDonkey1
| Sun Nov 18, 2012 7:25 pm |
wm
Joined: Sat Feb 19, 2011 11:48 pm Posts: 782 Location: Eau Claire Wi
unless hes just using to soft of a nut then it would push through the threads on the nut
_________________ 1648 alumacraft with a 35 backwaterinc
| Sun Nov 18, 2012 7:46 pm |
sdm111
I'll try lowering the shaft cause the threads do go into the collar how far i don't know thanks.
| Sun Nov 18, 2012 11:19 pm |
[ 7 posts ] |
