| Shaft prop nut creeping up to seal collar http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=34437 |
| Author: | sdm111 [ Sun Nov 18, 2012 4:24 pm ] |
| Post subject: | Shaft prop nut creeping up to seal collar |
Having a problem with nut between prop and seal collar creeping up to the collar. Any ideas how to keep it against the prop? BTW it's an OLD 8hp go-devil. When I got it not too long ago it was riding on the seal so I lowered the nuts prop etc. per go-devil cause it'll seize now it won't stay down |
| Author: | autogateman [ Sun Nov 18, 2012 5:03 pm ] |
| Post subject: | Re: Shaft prop nut creeping up to seal collar |
Loosen shaft in upper u joint and slide it down. Then retighten everything. |
| Author: | SwampDonkey1 [ Sun Nov 18, 2012 7:14 pm ] |
If there is room on the threads to use two jam nuts in front of the prop? Take those two and crank 'em together on the shaft to act as a stop. |
| Author: | autogateman [ Sun Nov 18, 2012 7:21 pm ] |
What I was saying is that the threads shouldn't be that close I the seal to begin with. |
| Author: | SwampDonkey1 [ Sun Nov 18, 2012 7:25 pm ] |
| Author: | wm [ Sun Nov 18, 2012 7:46 pm ] |
unless hes just using to soft of a nut then it would push through the threads on the nut |
| Author: | sdm111 [ Sun Nov 18, 2012 11:19 pm ] |
I'll try lowering the shaft cause the threads do go into the collar how far i don't know thanks. |
