It is currently Fri Apr 03, 2026 2:15 am
Reply to topic  [ 10 posts ]
 thrust bearing setup?
Post thrust bearing setup?
im in the process of building a 16 hp longtail and im going with bushings in the shaft and on the end if i cant find a reasonable price to machine cups for bearings to slip into. for the top bearing im going to use a two hole flange bearing that will be mounted to a peice welded to the shaft housing. my question is where do i need a thrust bearing and what is the purpose? another question is do i need to seal the lower bushing on the prop end? aslo how long will my threads for the prop be? trying to get everything ordered. and dont give me the crap about the search buttom ive used it and cant find anything dont need any smart comments.
thanks
Tue Nov 27, 2012 9:44 pm
Post Re: thrust bearing setup?
not sure about thread length, but yes you need to seal the prop end of the shaft, and have a way to grease it. you dont need a thrust bearing, that is for a radial load as if something was pushing inline with the shaft. just make sure your u joint has a keyway and tighten it very securely
Tue Nov 27, 2012 9:48 pm
thank you sir so i cant use a a flanged sleve bearing on the prop end? i need to put a regular sleeve bearing and then two or three oil seals?
Tue Nov 27, 2012 10:13 pm
Correct. Best way is to thread the end of the shaft tube and have your seals thread in like GD and the others do.
Tue Nov 27, 2012 10:21 pm
how much can i expect to pay for the threading and machining the cup?
Tue Nov 27, 2012 10:34 pm
i have another question also. i want a throttle control that is like a bicycle brake handle where you squeeze the lever for more gas where can i find one of those?
Wed Nov 28, 2012 12:17 am
You can rig up a bicycle brake lever with a throttle cable. You can buy them at MB or Bog Hog website. You also need operator presence switch(emergency disconnect)
Wed Nov 28, 2012 7:06 am
Profile YIM
What bearings you using in the lower end? I could machine a cup for you
Fri Nov 30, 2012 11:13 am
i havent decided on the bearings for the lower end becaue i want to use the ones that will be able to fit in the cup the best. obviouly the sealed bearings with a few oil seals.
Tue Dec 04, 2012 12:48 am
