It is currently Sun Apr 05, 2026 7:50 pm
Reply to topic  [ 11 posts ]
 Longtail on a 15' jon boat
Post Longtail on a 15' jon boat
Hey guys, I have 15' jon boat that im currently running a 13hp Honda on and it seems to have little to no power. I think the prop I have is too big for one, its a 9X5. Is a 13hp a good size or should I get a bigger motor? Also what kind of trim set ups do you guys have? Mine is just a bolt on the back that I screw up and down that pushes up on the botom plate but its a pain to have to reach around to the back of the motor to screw it up and down. Any suggestiosn would be awesome!!!
Thanks
Thu Dec 20, 2012 1:51 pm
Post Re: Longtail on a 15' jon boat
I have a 15 foot Tracker with a 16hp GDLT. Runs pretty good. I get about 16 mph with two people and gear loaded in it. I don't know that I would put too much more engine on the back of this boat though. I would like to see what a 23 hp would feel like though. Just don't know if the transom could handle it, being a cheap, riveted boat and all.
Thu Dec 20, 2012 1:55 pm
Thu Dec 20, 2012 1:57 pm
It will feel like that at first if you are used to outboards. But just wait until you get it in the mud. Speed will be meaningless then.
Thu Dec 20, 2012 2:07 pm
Prop is 2 big. My 20 calls for a 9 x 4
Fri Dec 21, 2012 7:11 pm
I run an 8x4 on the same engine on a 1436
Fri Dec 21, 2012 7:30 pm
I never seen a trim adjustment on a longtail. I just adjusted my cavitation plate so the motor dont blow out the water. Let it run the depth it wants
Fri Dec 21, 2012 8:12 pm
Sat Dec 22, 2012 10:24 am
27 GDLT pushing a War Eagle 1542
Sat Dec 22, 2012 10:54 am
I wouldn't think the size prop you are running would kill the motor unless it has other issues. It just wouldn't get enough rpm's under load. Just be bogged down.
Sat Dec 22, 2012 12:40 pm
Sat Dec 22, 2012 8:15 pm
