It is currently Thu Apr 09, 2026 5:44 pm
[ 5 posts ] |
Need a kill switch kit and starter button
StumpJumper1
I need to install a kill switch kit on my '93 gdlt 16. Anyone know where I can find one?
I also need a new button for my electric starter. I guess the old one got ripped off and now I only have wires. Where can I find one of those?
| Wed Dec 26, 2012 8:53 am |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
 Re: Need a kill switch kit and starter button
I suggest you order these from the factory when you order your throttle cable. If you have the serial number from the frame they will make sure you get the right part.
_________________ so many rivers, so little time
| Wed Dec 26, 2012 9:41 am |
Docott
Acadeny has kill swithches. Autozone has starters.
_________________ Phil Robertson said,"It seems like, to me, a vagina -- as a man -- would be more desirable than a man's anus,"
| Wed Dec 26, 2012 10:46 am |
SouthernWake
How do yo wire in push button starter? I have an electric start gx390 clone with the litte ignition unit that bolts to the side and would love a start button next to my kill button on the handle
| Wed Dec 26, 2012 3:21 pm |
Docott
Not familiar with that motor, but all an ignition switch (or the switch on the motor) is, is a momentary switch. when you push the button down, it make the electrical connection between the battery and the starter. When you let it go, the connection is broken. Works the same as any other switch except it doesn't stay on. Wire from battery to switch. Then from switch to starter. Probably some grounds and fuses in there somewhere, but that's basically it.
| Wed Dec 26, 2012 3:45 pm |
[ 5 posts ] |
