| Sealing top shaft http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=36202 |
| Author: | Joel907 [ Wed Jan 09, 2013 5:24 pm ] |
| Post subject: | Sealing top shaft |
Building a 16hp longtail I'm just going to use bushings At both ends. I don't think I did a good job sealing the last longtail I built I just sandwich the seals between two bushings. What's another way? |
| Author: | SwampDonkey1 [ Wed Jan 09, 2013 6:29 pm ] |
| Post subject: | Re: Sealing top shaft |
Stack the seals on the outside of the bushings, not on the inside... stack 4 going out in out out and 2 in the top going out... The object is to keep grease around the bushings... |
| Author: | Joel907 [ Thu Jan 10, 2013 10:59 am ] |
I did that but holding the in what I did was take a flang bushing And sandwich them together on both ends should I have made a housing. |
| Author: | SwampDonkey1 [ Thu Jan 10, 2013 12:13 pm ] |
yes |
| Author: | Joel907 [ Thu Jan 10, 2013 12:36 pm ] |
You have a pic |
| Author: | SwampDonkey1 [ Thu Jan 10, 2013 7:14 pm ] |
Search harder.... There is a wealth of info on this site and this topic has been discussed many times... larger pipe welded over the end of the shaft housing |
| Author: | Joel907 [ Thu Jan 10, 2013 10:05 pm ] |
Ya but what holds your seals in ? |
| Author: | SwampDonkey1 [ Thu Jan 10, 2013 10:23 pm ] |
some form of cap, you can thread the outside of the housing to accept a cap to hold it all in, with a hole for the shaft... I guess you could tack on a washer at the end but if you gotta replace it know youll have to buzz off them tacks and reweld a cap on when youre done |
| Author: | Joel907 [ Fri Jan 11, 2013 10:02 am ] |
I would think you would damage your seal pushing it past the threads |
| Author: | ds541 [ Fri Jan 11, 2013 10:43 pm ] |
don;t push your seals past/over the threads turn them or screw them on like a nut.less chance of doing damage to them. |
| Author: | SwampDonkey1 [ Sun Jan 13, 2013 1:23 am ] |
Just take some electrical tape and cover the threads.... slide on seals.... remove tape... |
