Engine swap on frame
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=36219
Author:  T_Moore [ Wed Jan 09, 2013 9:46 pm ]
Post subject:  Engine swap on frame
I have a 16hp GDLT with a vanguard v-twin, and have access to a 21hp vanguard v-twin for $100 running. Are the motor blocks that same size, and will the 21hp slide right into my frame? Or are they different sizes and require frame modifications?
Author:  take'emgator [ Wed Jan 09, 2013 9:58 pm ]
Post subject:  Re: Engine swap on frame
may need to check and make sure shafts are comparible if so you'll be fine, might need a new u-joint to bolt new motor up.
Author:  Gameover [ Thu Jan 10, 2013 7:13 am ]
i did way back in day when i had a 18 GDLT and swapped motors to a 23HP. The cavitation plate angle changed on different hp motors. You will need to call COCO and ask him if you would need to change your he will know.
Prepare for a bunch of BS with him telling you that you wont see much change switching up
Author:  goodblasson [ Thu Jan 10, 2013 8:47 am ]
As long as the shaft size is the same its a direct swap. If you have a genuine godevil frame look and see where the serial number is and right by it you should see (16-23 BS 6ft).
Author:  Gameover [ Thu Jan 10, 2013 8:50 am ]
the frames are the same but the angle at which the cav plate is welded on is not.
Author:  goodblasson [ Fri Jan 11, 2013 12:17 pm ]
Author:  SwampDonkey1 [ Sun Jan 13, 2013 1:28 am ]
Author:  Bayport [ Fri Jan 18, 2013 12:15 pm ]
But u can somtimes compensate for that simply by bending the end of the plate up or down
Author:  T_Moore [ Mon Jan 21, 2013 9:14 pm ]
I bought a 2011 model 21hp v-twn for $150 running, roughly 100hrs on it. Who do I need to talk to to figure out what angle to move my cavitation plate too. And it s a GD frame....
Author:  SwampDonkey1 [ Tue Jan 22, 2013 12:38 am ]
