Joel907
 Sealing top shaft
Building a 16hp longtail I'm just going to use bushings At both ends. I don't think I did a good job sealing the last longtail I built I just sandwich the seals between two bushings.
What's another way?
| Wed Jan 09, 2013 5:24 pm |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
 Re: Sealing top shaft
Stack the seals on the outside of the bushings, not on the inside... stack 4 going out in out out and 2 in the top going out... The object is to keep grease around the bushings...
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Wed Jan 09, 2013 6:29 pm |
Joel907
I did that but holding the in what I did was take a flang bushing And sandwich them together on both ends should I have made a housing.
| Thu Jan 10, 2013 10:59 am |
SwampDonkey1
yes
| Thu Jan 10, 2013 12:13 pm |
Joel907
You have a pic
| Thu Jan 10, 2013 12:36 pm |
SwampDonkey1
Search harder.... There is a wealth of info on this site and this topic has been discussed many times... larger pipe welded over the end of the shaft housing
| Thu Jan 10, 2013 7:14 pm |
Joel907
Ya but what holds your seals in ?
| Thu Jan 10, 2013 10:05 pm |
SwampDonkey1
some form of cap, you can thread the outside of the housing to accept a cap to hold it all in, with a hole for the shaft... I guess you could tack on a washer at the end but if you gotta replace it know youll have to buzz off them tacks and reweld a cap on when youre done
| Thu Jan 10, 2013 10:23 pm |
Joel907
I would think you would damage your seal pushing it past the threads
| Fri Jan 11, 2013 10:02 am |
ds541
don;t push your seals past/over the threads turn them or screw them on like a nut.less chance of doing damage to them.
| Fri Jan 11, 2013 10:43 pm |
SwampDonkey1
Just take some electrical tape and cover the threads.... slide on seals.... remove tape...
| Sun Jan 13, 2013 1:23 am |
