It is currently Sun Apr 12, 2026 3:44 pm
Reply to topic  [ 11 posts ]
 Grass around the prop
Post Grass around the prop
The pic was taken the morning after and the grass has dried out, but you can get the jist of my question. Is this normal? I'm thinking that the gap between the upper prop nut and the seal housing is too large. Thoughts?
Sent from my Galaxy S3 using Tapatalk 2
Fri Dec 21, 2012 11:33 am
Post Re: Grass around the prop
Looks normal to me. Keep a razor knife handy
Fri Dec 21, 2012 11:35 am
normal... cut it out before it gets that bad...
I gave up mud motors
Fri Dec 21, 2012 11:38 am
Okay...just wanted to check. We typically just pull into shallow water and commence to cutting. Guess we were on the right path.
Thanks for the help.
Fri Dec 21, 2012 3:13 pm
In that ropey grass it's not unusual to get some in that area, but it does appear the clearance is excessive. Distance from the upper jam nut to the face of the seal collar should be 1/4 to 3/8 inch. Check your GoDevil manual. If you don't have one you can download it from their website.
Fri Dec 21, 2012 4:24 pm
I thought the space may have been a little much, but it's only about 1/4" or maybe a bit less.
Anyone seen the grass cutter made from 1/8" plate that is welded onto the skeg? I'd love to get a pic.
Fri Dec 21, 2012 8:28 pm
DOn't run it contiuously like that cause the grass can damage your lower seal. Its normal to get grass right there, they all do it especially when the grass is thick.
Except with my GTR i just grab the reverse and sling it off
Fri Dec 21, 2012 11:43 pm
1850 Uncle J
Delta Performance level 4 GTR
Fri Dec 21, 2012 11:58 pm
Normal
Brandon MacDonald
B. MacDonald
Tue Jan 01, 2013 3:59 am
I run through thick wild rice during the duck season and It will happen to me when I am pushing real slow at low rpm. No doubt it will slow you down.
Tue Jan 01, 2013 8:23 pm
This site is awesome, You have answered alot of the questions I have. I have been having the same problem with bullrush getting into the space behind the prop. There is a nut between the prop and the shaft and I can't get all the grass out without removing it. I removed the front two nuts no problem but I cant get the prop to budge. Is the prop threaded? It's a BogHog motor.
Rich
Aluma Weld 16' X 49"
Bawg Hawg 27hp Kohler
Thu Jan 17, 2013 12:59 pm
