LT on Gatortrax Rogue
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=36755
Author:  Cubman [ Wed Jan 23, 2013 12:48 pm ]
Post subject:  LT on Gatortrax Rogue
Can you run a longtail on a Gator Trax Rogue with huntdeck? Or will the motor hit the false transom when you pick the prop up out of the water?
Author:  barnes_53 [ Wed Jan 23, 2013 12:52 pm ]
Post subject:  Re: LT on Gatortrax Rogue
the handle on the longtail has a curve that extends upward that allows for transom clearance. Since the motor is mounted further back I would think your chances of hitting the false transom are lower than with a traditional transom.
Author:  Cajunwannabe [ Thu Jan 24, 2013 9:03 pm ]
I believe the "tail" will hit the false transom. If mounted on the false transom it will be a bear to turn.
Author:  irons [ Mon Feb 18, 2013 4:38 pm ]
How do the Longtails fair with a huntdeck??? dont see to many of them after looking around the site...just curious
Author:  Cajunwannabe [ Thu Feb 21, 2013 4:49 pm ]
Author:  irons [ Thu Feb 21, 2013 9:25 pm ]
Sweet thanks, so as in the thread above you just don't mount the motor on the huntdeck? Just the transom?
Author:  Cajunwannabe [ Fri Feb 22, 2013 6:43 am ]
If you mounted it all the way back on the rear hunt deck transom it would be impossible to turn. You would have to be outside the boat trying to steer it.
Author:  irons [ Sun Feb 24, 2013 1:40 pm ]
Touchè sir. Good call
