sika hunter
 16hp Godevil
Would like to know if this would be the right size to put on a 12x32 jon boat ? I'm new to long tails so I don't wount to go too big . I did run a 6hp mud buddy ahd it just didn't get it done .
| Fri Jan 25, 2013 11:30 pm |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
 Re: 16hp Godevil
eh that could get a little dicey, might be alright though.
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Sat Jan 26, 2013 11:38 am |
cb5331
 Re: 16hp Godevil
There is no right size longtail for that boat. You should start over.
| Sat Jan 26, 2013 1:59 pm |
pinepointer
Joined: Tue Jul 24, 2012 7:42 am Posts: 115 Location: Toronto, ON, Canada
 Re: 16hp Godevil
I have that motor on a 16'x38" Scott Duckboat and it is just wide enough to float the weight at the stern. Putting a 16 GDLT onto a boat 4' shorter and 6" narrower is likely to have the transom riding very low in the water. The 6 hp MBLT may have seemed slow but it is probably about as heavy a rig as that size boat can safely balance.
_________________ 6.5 HP GDLT/ 12' Springbok or 15'4" Gheenoe or TDB Classic 14'
| Sat Jan 26, 2013 2:12 pm |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
 Re: 16hp Godevil
I agree with cb5331. It's approaching 25 years that I have been running mudmotors in Alaska. I have never had too much horsepower. More than once I have had too little boat. Start by looking at the loads you want to carry (including the weight of the motor) under the worst case conditions. Get a boat that will satisfy that criterion. From that point the choice of motor boils down to how fast do you need to go and what will the wife allow you to spend. I think your boat is 4 feet short and 10 inches narrow, but I'm old and have gotten more conservative over the years.
_________________ so many rivers, so little time
| Sat Jan 26, 2013 5:29 pm |
sika hunter
 Re: 16hp Godevil
Thanks for the replys . It's seems that motor wt. is the thing here , so how about if I put pods on the boat will that do it ? I do need the speed as I have a 2-4 mile ride .
| Sat Jan 26, 2013 6:50 pm |
SwampDonkey1
 Re: 16hp Godevil
take the $400+ you would spend on pods, and set it aside. Sell your rig you have now or just outright buy something larger. I bought a 1436 with trailer and outboard for $500, sold the outboard for $300 and was only $200 in on a nice little rig to handle a 16hp.
| Sat Jan 26, 2013 6:57 pm |
OlSchool
Joined: Sun Jan 06, 2013 4:24 pm Posts: 384 Location: Louisiana
 Re: 16hp Godevil
I wouldn't run the 16 on that boat. The 16 is pretty heavy and it would actually be faster on a longer boat. Something like 14x42 or 15x42.
| Sat Jan 26, 2013 8:46 pm |
sika hunter
 Re: 16hp Godevil
Thanks all ! A bigger boat it is .
| Sat Jan 26, 2013 8:57 pm |
sika hunter
 Re: 16hp Godevil
Sorry I need to ask again because it's not a 12x32 . It's a 12x36 will this make a difference ? I'm looking for fast safe but fast . I don't hunt out of it I just go to and from my sika spots .
| Wed Jan 30, 2013 5:42 pm |
cb5331
 Re: 16hp Godevil
No difference. The hull is too short to ever get a mm to perform worth a shit on it.
| Wed Jan 30, 2013 5:47 pm |
sika hunter
 Re: 16hp Godevil
So what would be a good size for speed and that motor ? Just asking because I can get a great deal on the motor .
| Wed Jan 30, 2013 6:50 pm |
pinepointer
 Re: 16hp Godevil
The previous owner of my motor had it on a 14'x48" jon boat and was very happy with the performance.
| Wed Jan 30, 2013 8:36 pm |
sika hunter
 Re: 16hp Godevil
Ok I need to ask would a 14x48 be the thing to get ? Like I said I'm new to this and need to get it right this time ! I started out with a kiyak (no room ) then I got a 10ft jon with the 6hp Too small was like rideing a jet ski . Then went to a 12ft jon with the 6hp mud buddy , too slow ! Went looking for a bigger motor and found the 16hp godevil . Seems to be a great deal at $1000 . I need to stay small because I go out a ditch with a lot of turns to get to the ponds . What would be a go combo ?
| Sat Feb 02, 2013 7:29 pm |
cb5331
 Re: 16hp Godevil
1448 is better than a 1236. Decent little boat for a 16, lots of people running that setup. Won't be fast and will push water with any kind of load, but nothing that small (boat and hp), and on that kinda budget is going to be very good.
| Sat Feb 02, 2013 7:31 pm |
T_Moore
 Re: 16hp Godevil
I run a 16hp on a 1436. I would love to have a 1448. The 1436 gets dicey in the left turns when your ass hangs over the side of the boat.. I get about 15hp with me in it, with 3 guys and duck hunting load you are looking a 7-8mph range. Its gotten through everything i have thrown at it... I really think the extra 12 in on the bottom would make a huge difference, yet reduce speed... Mine is rivetted and I put stellflex on the bottom. Steelflex is great stuff, but it has chipped and cracked from the way i have had to winch it on the trailer in these low water conditions....
| Mon Feb 04, 2013 4:41 pm |
Mike W.
Joined: Thu Jan 15, 2009 2:26 pm Posts: 146 Location: Vanceboro, NC
 Re: 16hp Godevil
Longtails run best on a long, skinny boat. My 16 x 38 will do around 21 / 22 mph with a 23 longtail. Go with AT LEAST a 16 ft. boat
_________________ "They call us civilized, cause we're easy to sneak up on!"
| Mon Feb 04, 2013 10:48 pm |
TonyGMcElroy
Joined: Tue Nov 15, 2011 3:27 pm Posts: 664 Location: Henderson, Tx
 Re: 16hp Godevil
Ive heard long and skinny for a longtail but i love my 1242 if its just me or 1 other person and light load but it fslls on its face with 3. If u run solo alot i would look into 1242, its light and stable. Im not sayin longer aint better because i havnt tried it but i personally woulsnt wanna go skinnier than 42
| Tue Feb 05, 2013 2:46 am |
