Da-Cajun-Angla
![Post Post](./styles/acidtech_tiger/imageset/icon_topic_latest.gif) installing honda kill switch...
i know im probably gonna get my balls busted 4 askin this but my motor never came with a kill switch, so ive never seen 1 installed. i bought 1 2day at walmart with the orange spiral cord and a bunch of plastic clips. where do i clip it on a honda engine? thanks, shaun
_________________ cajun: its real simple, we live back hea', dis' is our home, an' nobody don' fuk wit' us!
Sun Aug 09, 2009 9:11 pm |
![](./styles/acidtech_tiger/theme/images/spacer.gif) |
Da-Cajun-Angla
![Post Post](./styles/acidtech_tiger/imageset/icon_topic_latest.gif) Re: installing honda kill switch...
yeah...ummmmmm.... ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif) thanxxx 4 da info
Wed Aug 19, 2009 1:32 pm |
POKER1
Where do you clip it? Or how do you wire it up. Not sure what your asking here. You buy the complete switch or just the pull lanyard?
Thu Aug 20, 2009 11:17 am |
backwaterballer
Joined: Sat Feb 21, 2009 9:39 pm Posts: 715 Location: Pearland Tx
Hey poker I got a 23 vangaurd where do I run the wires to from the kill switch
_________________ 23 hp gdlt pushin the 14ft NoWeld "aka" the black pearl 35 hp gdsd pushin a 16/60 go devil boat
Thu Aug 20, 2009 11:41 am |
gooseaholic
Joined: Sat Jul 04, 2009 12:12 pm Posts: 16 Location: Whitewater, WI
I have the same problem with a new Honda I got... Help us Please!
_________________ 1651 Polar Kraft/ GTR35
Thu Aug 20, 2009 7:16 pm |
POKER1
Not sure with the Honda, but was just trying to clarify. You need a wiring diagram for the switch itself.
Thu Aug 20, 2009 8:46 pm |
POKER1
Not sure about your setup but all it does is break the circuit. Probably wired into the hot wire on the key switch.
Thu Aug 20, 2009 10:14 pm |
Da-Cajun-Angla
I BOUGHT AND INSTALLED A KILL SWITCH...i installed a normally open switch which i spliced directly inbetween the wire that connects the motor kill switch. well, if the motor kill switch is in the on position i figured out, i can only kill the engine by pressing the button and holding it a few seconds and my engine dies...lol...so its bass-akwards! u need to install a normally closed switch directly inbetween the motor kill switch wires i believe...i gotta buy one...so ill keep yall posted...but it may be that one wire needs to go to ground and the other one inline...sh!t this is aggravating!
Mon Aug 24, 2009 7:54 am |
gooseaholic
Ok... I got it! The switch I bought has both... Normally open and normally closed. With the lanyard teather attached, I chose the open contacts. I ran one wire fron the switch to ground and spliced the other to the ignition wire (black/red). When the teather is pulled... the switch makes contact and grounds the ignition. Thus grounds out the power to the coils and the engine looses spark and dies. The ignition wire is the wire that supplies voltage to both coils. I am quite sure this will work with any engine... even your duk truk... Hope that helps!
Mon Aug 24, 2009 3:52 pm |
gooseaholic
I tried to kill my motor by disconecting every wire I could... I even pulled the fuse while it was running... Nothing stopped that motor or even made it miss... The only way to do it is ground out the ignition...
Mon Aug 24, 2009 3:56 pm |
gooseaholic
Oh... I just checked my buddies Go-Devil... It has a Kohler. There is one wire connected directly to ground... and I can't tell where the other one is going... It's under the cover.
Mon Aug 24, 2009 4:00 pm |
