It is currently Thu Apr 09, 2026 8:27 pm
[ 5 posts ] |
predator 13 hp fuel tank question
coupe1975
The predator 13 hp engine has a fuel tank built on the engine. What would it take to use a external fuel tank? I have the hose and bulb and fittings etc. What could I do about a fuel pump. My godevil has one on the b/s would something like that work and how could I set it up. Thanks for any help
| Thu Apr 25, 2013 7:13 pm |
bobbyjober
Joined: Sun Aug 08, 2010 3:28 pm Posts: 546 Location: St. Martinville, La
 Re: predator 13 hp fuel tank question
You need to install a pulse fitting to operate a fuel pump. Check out affordablegokarts.com, there is a picture tutorial in fuel pulse fittting install to operate fuel pump.
_________________ 1542 FLATBOTTOM WITH 24 HONDA MUD BUDDY MINI TURNING A 12" GDSD PROP/17 FT XPRESS CENTER CONSOLE WITH 90 MARINER
| Thu Apr 25, 2013 7:43 pm |
SouthernWake
| Fri Apr 26, 2013 5:13 am |
AJCsurf
good luck!
| Fri Apr 26, 2013 7:45 am |
coupe1975
How far would this pulse pump draw the fuel? I'm wanting to put a larger fuel tank up into the front of the boat. I would be using about 14 feet of fuel line. Is this do able?
| Fri Apr 26, 2013 9:34 pm |
[ 5 posts ] |
