It is currently Sun Sep 21, 2025 11:41 pm
Reply to topic  [ 4 posts ]
 Go Devil prop vs. Mudbuddy prop
Post Go Devil prop vs. Mudbuddy prop
Does anyone know if a go devil prop will fit on a mudbuddy? I have a 27 hp MBLT and my hunting buddy has a 25 hp GDLT. We were discussing props and wondered if the two are compatible.
Mon Aug 17, 2009 6:19 pm
Post Re: Go Devil prop vs. Mudbuddy prop
the 2 sizes are 7/8" or 3/4"...as long as the shaft size is the same u r ok!
shaun
cajun: its real simple, we live back hea', dis' is our home, an' nobody don' fuk wit' us!
Mon Aug 17, 2009 9:01 pm
When you measure da pro do you measure from the center of the shaft to the out side edge of the prop to see if it is worn down. I have a 25 gdlt and it is 9x6 but only measures 8x5 if i am do it right but not sure.
1746 with a modded 35 gdsd
Capt Team total asalt
Mon Sep 28, 2009 7:39 pm
On a 9x6 prop the pitch is 6" forward per revolution in a perfect world
of no slip or friction --- the diameter from tip to tip is 9 inches...
Often the pitch is stamped into the hub -- but only a prop shop can
accurately measure your pitch...
Mon Sep 28, 2009 7:42 pm
