| Go Devil prop vs. Mudbuddy prop http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=3983 |
| Author: | dead duk [ Mon Aug 17, 2009 6:19 pm ] |
| Post subject: | Go Devil prop vs. Mudbuddy prop |
Does anyone know if a go devil prop will fit on a mudbuddy? I have a 27 hp MBLT and my hunting buddy has a 25 hp GDLT. We were discussing props and wondered if the two are compatible. |
| Author: | Da-Cajun-Angla [ Mon Aug 17, 2009 9:01 pm ] |
| Post subject: | Re: Go Devil prop vs. Mudbuddy prop |
the 2 sizes are 7/8" or 3/4"...as long as the shaft size is the same u r ok! shaun |
| Author: | slingshot [ Mon Sep 28, 2009 7:39 pm ] |
When you measure da pro do you measure from the center of the shaft to the out side edge of the prop to see if it is worn down. I have a 25 gdlt and it is 9x6 but only measures 8x5 if i am do it right but not sure. |
| Author: | Gigafowl [ Mon Sep 28, 2009 7:42 pm ] |
On a 9x6 prop the pitch is 6" forward per revolution in a perfect world of no slip or friction --- the diameter from tip to tip is 9 inches... Often the pitch is stamped into the hub -- but only a prop shop can accurately measure your pitch... |
