It is currently Fri Apr 03, 2026 10:17 am
Reply to topic  [ 11 posts ]
 hauling 25hp godevil
Post hauling 25hp godevil
Going to pick up my longtail today. Do all go devil longtails swivel into the boat for easier transport or does it just hang out the back of the boat?
Fri Apr 19, 2013 6:40 am
Post Re: hauling 25hp godevil
Its an option u can get
1944 skiff with 35 GTR
Fri Apr 19, 2013 6:57 am
So can I add it to mine or does it have to come factory?
Fri Apr 19, 2013 7:32 am
Yeah call go devil and tell them u want the swivel bracket for trailering
Fri Apr 19, 2013 7:50 am
Find the serial number stamped on your frame just in case they ask you for it.
Fri Apr 19, 2013 3:29 pm
Yeah. I gave em serial number and they said $165. Thanks for the info guys
Fri Apr 19, 2013 3:33 pm
Fri Apr 19, 2013 6:23 pm
My MB LT came with a swivel bracket. I lengthened the battery and gas lines to allow me to do this but I did not like the weight of the motor hanging farther back so I went back to the "conventional" method. For night trailering I can suggest adding a movable third light to the prop end.
Fri Apr 19, 2013 8:37 pm
Wed May 08, 2013 9:27 am
10-4 on that bike light! What Gigafowl said. I use two sets of heavy duty bungee tie downs- one looped around like the GD way. Of course the gunwale strap is kind of a fail safe. If you have a rear bench seat, a boat cushion or the like is indicated between the handle/seat if they make contact to soften bumps. An additional tie down can be placed from the mid-frame shaft area to the rear boat handles (if you have them) or suitable tie points to prevent any side to side sway while trailering. To avoid those little ole ladies, I leave real early and use my emergency lights if necessary when vehicles are approaching from behind.
Wed May 08, 2013 2:14 pm
I know on my next longtail I will get the swivel added. Just turn your motor in your boat throw a strap over it and it is locked down.
23hp GDLT on 16x38 GD boat
When up to your nose in shit, don't open your mouth.
Sun Jun 09, 2013 12:45 pm
