It is currently Sat Apr 11, 2026 12:19 pm
Reply to topic  [ 5 posts ]
 predator 13 hp fuel tank question
Post predator 13 hp fuel tank question
The predator 13 hp engine has a fuel tank built on the engine. What would it take to use a external fuel tank? I have the hose and bulb and fittings etc. What could I do about a fuel pump. My godevil has one on the b/s would something like that work and how could I set it up. Thanks for any help
Thu Apr 25, 2013 7:13 pm
Post Re: predator 13 hp fuel tank question
You need to install a pulse fitting to operate a fuel pump. Check out affordablegokarts.com, there is a picture tutorial in fuel pulse fittting install to operate fuel pump.
Thu Apr 25, 2013 7:43 pm
Profile YIM
Fri Apr 26, 2013 5:13 am
good luck!
Fri Apr 26, 2013 7:45 am
How far would this pulse pump draw the fuel? I'm wanting to put a larger fuel tank up into the front of the boat. I would be using about 14 feet of fuel line. Is this do able?
Fri Apr 26, 2013 9:34 pm
