It is currently Thu Apr 09, 2026 12:30 pm
Reply to topic  [ 10 posts ]
 Question on longtail bearing design
Post Question on longtail bearing design
Hello,
I am newbie here as I have been just lurking and reading up until now.
I am getting ready to do my first longtail build and wanted to shoot my bearing idea past some of you. I have the machining tools, and ability to make the following, but was wondering if this bearing set up would be a good one. I wanted to take out all the thrust load issues by using a tapered bearing on each end, with a bushing in the middle. The top end would be very similar, except the collar that rides on the inner race would be pinned in place. The drawing is not to scale, as I do not have a cad program and had to use paint shop. Any feedback would be appreciated.
Thanks,
Jim
Tue Apr 30, 2013 12:00 pm
Post Re: Question on longtail bearing design
Maybe this drawing will clear it up a bit.
Let me know what you think?
Jim
Tue Apr 30, 2013 1:36 pm
What seals between your spacer and shaft?
Tue Apr 30, 2013 2:40 pm
Both the inner race of the taper bearing, and the spacer will be a tight slide fit on the shaft, so I am not thinking there will be any trouble with grease escaping there. I may be mistaken though.
Tue Apr 30, 2013 3:24 pm
I think with that spacer, you may have a pretty high friction point.
Tue Apr 30, 2013 6:41 pm
The spacer will be turning with the shaft, nut, and inner bearing race, so the only friction point should be the seals.
Thanks,
Jim
Wed May 01, 2013 1:36 am
Quote:
We had a lot of hunters from down under. All a bunch of great guys that liked to drink, root, and shoot shit in the dark. My kind of people.
Wed May 01, 2013 3:25 am
I like the fact your thinking but this won't last.
Wed May 01, 2013 5:40 am
Wed May 01, 2013 5:59 am
Thanks guys, this is exactly why I posted it. It is always better to have several eyes look at a project. Especially when I am going into this without ever seeing a longtail in person. This first one I will make just as the plans I received called for. Then I can putz on the next one, trying some "Improvements"
Thanks again!
Jim
Wed May 01, 2013 9:30 pm
