Powerstroke9773
Joined: Tue Apr 05, 2011 8:01 pm Posts: 164 Location: Nixonton, North Carolina
 v hull or flat bottom
Just curious i have a 20hp gdlt and im about to get a 14 foot v hull for free how will the lt do on a v hull its 14 foot by the way
_________________ 17Foot Aquasport 85 Evinrude 20GDLT Looking for a Hull
| Thu May 09, 2013 9:07 pm |
Glades Ranger
Joined: Mon Sep 19, 2011 6:32 pm Posts: 1490 Location: south Florida
 Re: v hull or flat bottom
Short answer is not so good...but it will work. A better fit would be a 15-17' hull. It all depends as well where you run and the load you carry: that 14', if it a riveter, thinner gauge hull, may require beefing up the transom area. You will have to be very careful with balancing the weight, turning, make sure you carry all requisite safety gear; make sure the kill switch works and wear the lanyard! This is most definitely a limited 2 man at most hunting boat but for free a good deal. Let us know how it goes.
_________________ Sailing in the sawgrass /1648 grizzly and Swomp 26.5 EFI
| Fri May 10, 2013 3:20 am |
Powerstroke9773
Ya i know its a bit big for the hull but what im askin is would a flat nose jon be better than a flat trans v hull
| Fri May 10, 2013 2:50 pm |
coupe1975
To the best of my knowledge is a longtail works best on a long skinny boat. I was told that a longtail works better on a flat bottom boat better then a v Hull or semi v Hull due to the fact of how the water flow from under the boat. On a flat bottom boat the water will gather up and start the head of the wake just where the longtail cav. Plate and prop ride. On a V style Hull this head of the wake is farther behind the boat making it not a efficient and harder to operate. now this is just what I've been told on mmt and unfortunately I can not verify this for you due to the fact I own a flat bottom. I ask the same question when I was looking for a rig. I was looking at a war eagle which is a semi V and was told by several people to stay away from a V so that's what I did. hope this help and you might.try to use the search feature on this site for better information
| Mon May 13, 2013 7:23 pm |
cut'em94
Joined: Tue Oct 02, 2012 6:16 pm Posts: 291 Location: Luling, LA
You will definitely see better performance on a long, skinny boat for a longtail.
| Mon May 13, 2013 7:33 pm |
guidry21
Joined: Thu Feb 14, 2013 1:33 pm Posts: 338 Location: galliano, la
i have a 25 longtail on a semi v and the ride and performance isn to bad i can't compare it to a flat bottom tho cause ive never owned one
_________________ 16x48 alweld 35 gtr
| Tue May 14, 2013 2:23 pm |
Glades Ranger
What Coupe said but I want to qualify what I posted- if you don't have a lot of mud, stumps, etc., you can get by with a semi-v like my tracker grizzly (not sure the angle of the bottom, partly vee mostly flat but has chines). I "cheated" a bit by adding steelflex (gatorglide is another product there are others) to help out over grass/mud areas by reducing friction. In those "hellilsh" marshes with all those impediments, a true flat skinny mud hull is the ticket for the LT.
| Wed May 15, 2013 6:29 am |
Powerstroke9773
It is a 14 foot skinny hull round chines flat all the way to the bow its just at the bow it comes to a V im not sure what kind of hull that makes it but it is long and skinny with flat bottom just has a V front
| Wed May 15, 2013 9:53 am |
Glades Ranger
Just use common sense and it will work fine! Can't beat the price!
| Wed May 15, 2013 12:18 pm |
coupe1975
X2^ but watch the semi v on the front on the boat because if you(sorry) when you hit a stump just under the water if its not dead center the boat will jump hard to the left or right so be sure to have a grab bar and WEAR your saftey kill switch and made sure it works. Because you may go swimming easier than with a flat bottom due to the angle on the bottom will catch the stump like a ramp. Good luck
| Thu May 16, 2013 7:10 pm |
Powerstroke9773
Ya thanks a lot guys i figured it would work iv looked at some of the mud run photos and seen guys running v feonts just wanted to get yals opinion its greatly appreciated how much more balls you think the 20hp will have compared to the 13 i used to have
| Thu May 16, 2013 9:15 pm |
coupe1975
Night and day difference
| Sat May 18, 2013 4:18 pm |
tylerduckman
Joined: Mon Jan 30, 2012 1:40 pm Posts: 844 Location: Tyler TX
Flat bottom!! The only way to go
_________________ Semper Fi
16x38 WC Skiff 35 MB HD
| Sat May 18, 2013 6:34 pm |
