It is currently Wed Apr 08, 2026 2:57 pm
Reply to topic  [ 10 posts ]
 Where is the Go Devil Serial number located?
Post Where is the Go Devil Serial number located?
I thought the sticker on the GD LT I bought had the serial number on it but looking at pics I think it is the patent number. One of the PO's sanded across the label and cut the numbers down to where they are hard to read. Not impossible to read, just hard and not on purpose, it looks like a orbital sander was run across the label as it has the small swirls cut into it. Anyway, I doubt that is important as I now don't think it has the serial number there. Where is it located?
Edit to add:
This is what my GD looks like, the 18HP briggs and all. I did not buy that one but it looks exactly like it.
Fri May 17, 2013 6:44 pm
Post Re: Where is the Go Devil Serial number located?
On the engine mounting plate directly under the u joint.
Fri May 17, 2013 6:57 pm
Fri May 17, 2013 7:14 pm
No problem! Best of luck!
Fri May 17, 2013 7:19 pm
Do you know what year serial numbers range in? This one ranges in the low 2000's.
Fri May 17, 2013 7:38 pm
No idea. GD will be able to tell you everything though.
Fri May 17, 2013 7:50 pm
That area was always covered with grease turds on my old GD motors. "Have grease gun will travel". :mrgreen:
Fri May 17, 2013 9:36 pm
6.5 HP GDLT/ 12' Springbok or 15'4" Gheenoe or TDB Classic 14'
Sat May 18, 2013 4:02 am
Mine is an 04 go devil and in the 16000 range
I think giga douche was bragging about go devil making motor number 25000 a lil while back
Sat May 18, 2013 6:35 am
Sat May 18, 2013 10:09 am
