Backh20 vs. Tiger prop?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=40895
Author:  berretax35 [ Sun May 19, 2013 3:30 pm ]
Post subject:  Backh20 vs. Tiger prop?
Is there much difference between these two for a 25hp longtail?
Author:  Glades Ranger [ Mon May 20, 2013 6:23 am ]
Post subject:  Re: Backh20 vs. Tiger prop?
All the LT mfg.'s make good props: GD, MB, BackH2O...I currently am running a Ron Hill prop which has been very good and sound and after four seasons shows little wear-I paid a lot less for it I use a 9x6 although the 27 HP I have is rated for the 9x7. So much on an LT is where you run, altitude, load, etc. You can't go wrong with whatever mfg. your motor is- a homebuilt you take your pick. You might find out what other LT users in your vicinity are running for their 25's. The MB Tiger prop was very good but I sheared it hitting some coral rock- guess any make would have been damaged as well. Before that happened I compared the Tiger and the Hill and the Hill was 1 mph slower. With my previous GD props, I noticed I actually gained 1-2 mph after some wear. My other advice is to get a backup with another set of washers and nuts; when you remove your prop, each time clean the threads and apply anti-seize.
Author:  Buzz Killington [ Mon May 20, 2013 4:44 pm ]
Backwaterinc.com props are great. Not very expensive and run very well.
Well worth it.
Author:  wing [ Mon May 20, 2013 8:04 pm ]
Has anyone received a new tiger prop. I have had from freinds order MB tiger prop and not get the tiger prop. I also read some posts about them not sending Tiger props.
Author:  wm [ Tue May 21, 2013 8:55 pm ]
Author:  KENNEDY [ Fri May 24, 2013 3:39 pm ]
We ran a 29hp mud buddy and switched from a tiger to backwater. And the back water doesn't seem to hold up as well as the tiger.
Just my .02
Author:  wm [ Mon Jun 03, 2013 5:48 am ]
Author:  KENNEDY [ Mon Jun 03, 2013 5:10 pm ]
About a year ago
Author:  katyg2895 [ Fri Jun 07, 2013 8:15 am ]
I don't think you can go wrong with a Backwater prop. Quality is great along with the customer service AND all the advice that comes with it is free.
Author:  Prodigy [ Fri Jun 07, 2013 8:17 am ]
What tiger r u looking for and I can get it for u if u need one.
Author:  Bigbuckfever [ Fri Jun 07, 2013 11:27 am ]
I like the backwaterinc prop for sure. May lose a little bit on top end, but load it up and the speed doesn't change much.
Sent from my DROID RAZR using Tapatalk 2
