25 Kohler not running
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=41047
Author:  AUgunner [ Thu May 23, 2013 8:53 pm ]
Post subject:  25 Kohler not running
I have been having issues with my 25 Kohler not wanting to run right. It doesn't appear to be getting fuel. I left the key on one night and I'm afraid I burnt up the fuel pump, so I replaced that. Then it would run somewhat but only on choke and then would spit and sputter, now it simply wont crank at all. I pulled the plugs and turned it over, it didn't blow out any gas at all. I then pulled the carb and cleaned it out really well, there was lots of gunk in the bowl and the needle valve was very seazed up. I got out all the junk, cleaned up the needle valve, and replaced the carb. Still nothing. I'm getting spark and still not getting gas. I'm at a loss here. I even went back and replaced the hose and priming bulb just for good measure.
The motor was running flawlessly the last time I took it out (when I left the key on and the fuel pump run for several hours), then when I tried to take it out the next time all hell broke loose and this is where I stand now. Any help would be greatly appreciated, I would really like to fix this myself instead of pay a small engine guy. Might do some upgrades while I'm working on it!
Author:  Cajunwannabe [ Thu May 23, 2013 9:17 pm ]
Post subject:  Re: 25 Kohler not running
check the fuel shutoff solenoid. Sounds like its burnt up and stuck shut.
you can either spend money to replace or:
Pro tip: Pull it out, cut the needle off and put it back in.
Author:  AUgunner [ Sat Jun 01, 2013 4:55 pm ]
Well I checked that and it had already been cut, also pulled the carb and had it cleaned really well. It's still not running. I'm at a loss. Unless I can come up with more ideas, I'm going to be taking it to a mechanic.
Author:  guidry21 [ Tue Jun 04, 2013 9:39 am ]
it sounds stupid but check make sure your inline filter is on in the right direction had that problem on an outboard and it wouldn't run
