It is currently Mon Apr 06, 2026 5:24 pm
[ 5 posts ] |
SBEII
 Synthetic Oil
I've read in numerous places that synthetic improves the performance of your motor. Just bought a new 35 HP Go-Devil. I put regular 30w oil in it for the break-in period and after 6 or 8 hours I'm planning on draining it and re-filling with synthetic. The question is.....If this motor was going to be running in temperatures from 0 degrees to 70 degrees...what would you use for Oil weight?? I'm leaning toward 10w 30. Anyone see a big problem with that?? Would I be better served with something else??
Thanks
| Mon Aug 24, 2009 7:52 am |
Mississippi Hunter
 Re: Synthetic Oil
If it is a Kohler, they reccomend running 10W-30 at 40-whatever temp and 5W-30 at 40 to -20. Check out the link below. http://www.kohlerengines.com/onlinecata ... p_2580.pdf
| Mon Aug 24, 2009 12:00 pm |
kibb
 Re: Synthetic Oil
It may good idea to run synthetic, but it's not recommended until you have at least 50 hours on the motor.
| Mon Aug 24, 2009 5:56 pm |
quackconsumer
 Re: Synthetic Oil
| Mon Aug 31, 2009 1:15 pm |
kibb
 Re: Synthetic Oil
That's what's recomended by small engine manufacturers. To ensure everything is properly seated, I assume.
| Mon Aug 31, 2009 5:24 pm |
[ 5 posts ] |
