| Synthetic Oil http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=4119 |
| Author: | SBEII [ Mon Aug 24, 2009 7:52 am ] |
| Post subject: | Synthetic Oil |
I've read in numerous places that synthetic improves the performance of your motor. Just bought a new 35 HP Go-Devil. I put regular 30w oil in it for the break-in period and after 6 or 8 hours I'm planning on draining it and re-filling with synthetic. The question is.....If this motor was going to be running in temperatures from 0 degrees to 70 degrees...what would you use for Oil weight?? I'm leaning toward 10w 30. Anyone see a big problem with that?? Would I be better served with something else?? Thanks |
| Author: | Mississippi Hunter [ Mon Aug 24, 2009 12:00 pm ] |
| Post subject: | Re: Synthetic Oil |
If it is a Kohler, they reccomend running 10W-30 at 40-whatever temp and 5W-30 at 40 to -20. Check out the link below. http://www.kohlerengines.com/onlinecata ... p_2580.pdf |
| Author: | kibb [ Mon Aug 24, 2009 5:56 pm ] |
It may good idea to run synthetic, but it's not recommended until you have at least 50 hours on the motor. |
| Author: | quackconsumer [ Mon Aug 31, 2009 1:15 pm ] |
| Author: | kibb [ Mon Aug 31, 2009 5:24 pm ] |
That's what's recomended by small engine manufacturers. To ensure everything is properly seated, I assume. |
