berretax35
Joined: Fri Dec 10, 2010 12:50 am Posts: 144 Location: dixie
 Backh20 vs. Tiger prop?
Is there much difference between these two for a 25hp longtail?
_________________ pintaildrake09 wrote: 42.850006 dont forget to gator glide the skeg, under armour clothes , and take a chit before you leave DmaxHunter wrote: But shit that's why they our motors and not yours
| Sun May 19, 2013 3:30 pm |
Glades Ranger
Joined: Mon Sep 19, 2011 6:32 pm Posts: 1490 Location: south Florida
 Re: Backh20 vs. Tiger prop?
All the LT mfg.'s make good props: GD, MB, BackH2O...I currently am running a Ron Hill prop which has been very good and sound and after four seasons shows little wear-I paid a lot less for it I use a 9x6 although the 27 HP I have is rated for the 9x7. So much on an LT is where you run, altitude, load, etc. You can't go wrong with whatever mfg. your motor is- a homebuilt you take your pick. You might find out what other LT users in your vicinity are running for their 25's. The MB Tiger prop was very good but I sheared it hitting some coral rock- guess any make would have been damaged as well. Before that happened I compared the Tiger and the Hill and the Hill was 1 mph slower. With my previous GD props, I noticed I actually gained 1-2 mph after some wear. My other advice is to get a backup with another set of washers and nuts; when you remove your prop, each time clean the threads and apply anti-seize.
_________________ Sailing in the sawgrass /1648 grizzly and Swomp 26.5 EFI
| Mon May 20, 2013 6:23 am |
Buzz Killington
Backwaterinc.com props are great. Not very expensive and run very well.
Well worth it.
B. MacDonald
| Mon May 20, 2013 4:44 pm |
wing
Has anyone received a new tiger prop. I have had from freinds order MB tiger prop and not get the tiger prop. I also read some posts about them not sending Tiger props.
| Mon May 20, 2013 8:04 pm |
wm
Joined: Sat Feb 19, 2011 11:48 pm Posts: 782 Location: Eau Claire Wi
_________________ 1648 alumacraft with a 35 backwaterinc
| Tue May 21, 2013 8:55 pm |
KENNEDY
Joined: Wed Apr 20, 2011 10:46 am Posts: 353 Location: Baytown, Texas
We ran a 29hp mud buddy and switched from a tiger to backwater. And the back water doesn't seem to hold up as well as the tiger.
Just my .02
_________________ WC CUSTOMS 18x48 PUSHED BY A 35GTA
| Fri May 24, 2013 3:39 pm |
wm
| Mon Jun 03, 2013 5:48 am |
KENNEDY
About a year ago
| Mon Jun 03, 2013 5:10 pm |
katyg2895
I don't think you can go wrong with a Backwater prop. Quality is great along with the customer service AND all the advice that comes with it is free.
| Fri Jun 07, 2013 8:15 am |
Prodigy
What tiger r u looking for and I can get it for u if u need one.
_________________ Prodigy Boats https://www.facebook.com/Prodigyboats www.prodigyboats.com Contact for info - http://prodigyboats.com/contact-us/ 706-253-7766
| Fri Jun 07, 2013 8:17 am |
Bigbuckfever
Joined: Sat May 28, 2011 11:18 pm Posts: 2114 Location: Slinger, WI
I like the backwaterinc prop for sure. May lose a little bit on top end, but load it up and the speed doesn't change much.
_________________ Every day I'm paddlin' 1848 Gatortail boat and 37 efi GTR.
| Fri Jun 07, 2013 11:27 am |
