It is currently Tue Apr 07, 2026 1:55 pm
Reply to topic  [ 12 posts ]
 DOM Tube
Post DOM Tube
fixing to build a 13horse honda longtail. Question I have is what size DOM tube are you guys using? ID and OD. I looked around and there are lots of choices. I am going to go with the flange bearing on the top with bronze bushings in the middle and bottom sections. thanks
Wed Jun 19, 2013 8:36 pm
Post Re: DOM Tube
1" id 1 ½"- 1 ⅜" od. Depends on how heavy duty you want it.
35 GTR chasin a BBC 1848
Fri Jun 21, 2013 1:46 pm
Post Re: DOM Tube
i was originally thinking 1.25" OD and 1" ID. I guess the extra thickness wont hurt anything. I just dont want it to be too heavy.
Fri Jun 21, 2013 7:55 pm
Post Re: DOM Tube
- Mark Twain
Fri Jun 21, 2013 8:30 pm
Post Re: DOM Tube
great yourself a copy of mad mud motor plans off of ebay that should help with some of your questions also the search function on this site is very helpful it has a wealth of information that will help with a mud motor build.
Fri Jun 21, 2013 8:36 pm
Post Re: DOM Tube
I have a set of thos plans with penciled in measurements for a 13hp hf predator I built last year.
Fri Jun 21, 2013 10:26 pm
Post Re: DOM Tube
i did sift throught the threads that the search function brought up but there was a lot of conflicting information. This will actually be my second 13 hp build for me but the first one I just used schedule 40 pipe for the housing. I want to do this one right. The dimensions for the Sch 40 are 1.32 OD and 1.05 ID. My thoughts were that it was overkill so i was going to downsize this time to the DOM 1.25 OD and 1" ID. If im wrong please correct me. I appreciate all the comments.
Sat Jun 22, 2013 7:21 am
Post Re: DOM Tube
concerning the home made builds
Is it cost effective to do so?
When one orders or fabricates all the parts, purchases the engine, and assembles a mud motor, how much is saved over just purchasing a name brand mud motor (I am sure there is a wide variance concerning horse power and other factors)?
Uncle J 18x54
Gator Tail XD 37 EFI -Delta Performance Level 3
Sat Jun 22, 2013 7:41 am
Post Re: DOM Tube
It depends on how much you buy premade and how much you actually fabricate. I would say as long as you don't factor any tool purchases in you save roughly half as long as you fabricate as much as possible. Plus it's a fun project for the off season
Sat Jun 22, 2013 8:13 am
Post Re: DOM Tube
1436 Lowe
Sun Jun 23, 2013 7:39 pm
Post Re: DOM Tube
I use 1.250 OD and .875 ID DOM in either steel or aluminum. I want enough metal in the tube wall to have substance for the threaded accessories. I think that .125 wall is a little thin for threads.
Mark F. Cheney
on the Great Salt Lake marsh
Sun Jun 30, 2013 1:44 am
Post Re: DOM Tube
yeah the .125 wall is getting fairly thin for threading anything into it. Im gonna go with 1.375" OD and 1" ID. should be a good compromise on strength and weigh.
Mon Jul 01, 2013 11:12 am
