It is currently Sat Apr 04, 2026 1:58 pm
Reply to topic  [ 5 posts ]
 Synthetic Oil
Post Synthetic Oil
I've read in numerous places that synthetic improves the performance of your motor. Just bought a new 35 HP Go-Devil. I put regular 30w oil in it for the break-in period and after 6 or 8 hours I'm planning on draining it and re-filling with synthetic. The question is.....If this motor was going to be running in temperatures from 0 degrees to 70 degrees...what would you use for Oil weight?? I'm leaning toward 10w 30. Anyone see a big problem with that?? Would I be better served with something else??
Thanks
Mon Aug 24, 2009 7:52 am
Post Re: Synthetic Oil
If it is a Kohler, they reccomend running 10W-30 at 40-whatever temp and 5W-30 at 40 to -20.
Check out the link below.
http://www.kohlerengines.com/onlinecata ... p_2580.pdf
Mon Aug 24, 2009 12:00 pm
It may good idea to run synthetic, but it's not recommended until you have at least 50 hours on the motor.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Mon Aug 24, 2009 5:56 pm
Mon Aug 31, 2009 1:15 pm
That's what's recomended by small engine manufacturers. To ensure everything is properly seated, I assume.
Mon Aug 31, 2009 5:24 pm
