It is currently Tue Apr 07, 2026 2:37 pm
Reply to topic  [ 19 posts ]
 Bicycle Brake Cable Throttle
Post Bicycle Brake Cable Throttle
I am trying to use the brake lever off of a bike for the throttle on a 23hp Briggs. What is the best way to attach the cable to the throttle lever at the motor end? The old cable was doubled back on itself and clamped with one of these, but it was a pain to adjust:
Wed Jan 16, 2013 9:37 pm
Post Re: Bicycle Brake Cable Throttle
the cable should have a barell or a piece on the end that slides into a slot on the lever
Thu Jan 17, 2013 7:45 am
1436 Lowe
Thu Jan 17, 2013 8:12 am
Sorry, I didn't explain that well. I'm trying to figure out how to attach it at the carb end of the cable.
Thu Jan 17, 2013 9:39 am
I just made a loop through a hole on the throttle lever and crimped it. Right or wrong its been working for years.
Tue Jan 22, 2013 2:23 pm
Yeah those things are garbage. There's one on my stumpjumper and it comes loose all the time.
Tue Jan 22, 2013 3:43 pm
Can you just replace the old throttle with a bike brake or do you need a new cable?
Tue Jan 22, 2013 4:37 pm
Got it set up. I drilled a hole through a bolt with a big shoulder on it, that bolts to the throttle and pivots. Then the cable stop clamps down on the cable.
The bike brake barely doesn't have enough throw. I may have to try a different handle.
Tue Jan 22, 2013 9:46 pm
i just replaced the original with the bike cable and has not failed me yet! also i crimped the barrel on the end. sure is nice having a bike lever for it way better than a standard throttle
Tue Jan 22, 2013 10:12 pm
I got the BPS on my stumpjumper. It takes some grinding but I got it on.
Wed Jan 23, 2013 9:32 am
Anyone tried the twist type throttle grip...from Sliphover throttle systems?
Wed Jan 23, 2013 9:46 am
1436 Lowe
Wed Jan 23, 2013 11:03 am
On my last build, I used a clutch engagement handle from a tiller. It has a bit more travel than a brake lever and was about $25 for the handle and 40" cable.
I will see if I can dig up some pictures.
Mag10
Wed Jan 23, 2013 12:19 pm
I can't get enough throw out of this bike brake handle. You can adjust it so the motor will idle, or hit WOT, but not both. I am thinking about ordering a BPS handle. Will their cable fit a 23hp Vanguard? How does it attach on the motor end?
Thu Jul 04, 2013 8:19 pm
You probably bought a short pull handle. They make a long pull handle too. Buy that one instead.
Thu Jul 04, 2013 8:36 pm
This is what I got from the local bike shop:
How do I tell if a lever is a long pull? Will this one do the job?
Thu Jul 04, 2013 9:01 pm
Search - lever style throttle , 20$ , 30 minutes .
I put one , clutch style , long throw from local motorcycle shop on my longtail .I listed the part # so anybody could order in the above post , I think it was in feburary. The kind I used would fit the go devil handle with no grinding or adjustments. Works great instant throttle response beats that stock throttle.
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Thu Jul 04, 2013 11:30 pm
Thanks HF. Somebody welded a section of 7/8" tube into the end of my handle though, so I need something smaller.
Fri Jul 05, 2013 12:15 am
Broke my old throttle yesterday so a bike brake throttle was the plan for the day.
Walked into a bike shop bought the cheapest brake lever and cable then put it all together.
Total of $15 and 45 min from getting off the couch to completion.
Sun Jul 07, 2013 4:36 pm
