Cubman
Joined: Sun May 16, 2010 8:53 pm Posts: 254 Location: East TN
 Bicycle Brake Cable Throttle
I am trying to use the brake lever off of a bike for the throttle on a 23hp Briggs. What is the best way to attach the cable to the throttle lever at the motor end? The old cable was doubled back on itself and clamped with one of these, but it was a pain to adjust:
| Wed Jan 16, 2013 9:37 pm |
SouthernWake
 Re: Bicycle Brake Cable Throttle
the cable should have a barell or a piece on the end that slides into a slot on the lever
| Thu Jan 17, 2013 7:45 am |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Thu Jan 17, 2013 8:12 am |
Cubman
Sorry, I didn't explain that well. I'm trying to figure out how to attach it at the carb end of the cable.
| Thu Jan 17, 2013 9:39 am |
Jim1648
Joined: Sat May 02, 2009 4:24 pm Posts: 115 Location: Michigan
I just made a loop through a hole on the throttle lever and crimped it. Right or wrong its been working for years.
| Tue Jan 22, 2013 2:23 pm |
rob_rides_03
Joined: Tue Oct 13, 2009 3:31 pm Posts: 202 Location: NJ
Yeah those things are garbage. There's one on my stumpjumper and it comes loose all the time.
| Tue Jan 22, 2013 3:43 pm |
Quack Stackin
Joined: Mon Feb 14, 2011 6:07 pm Posts: 759 Location: NE ALABAMA
Can you just replace the old throttle with a bike brake or do you need a new cable?
| Tue Jan 22, 2013 4:37 pm |
Cubman
Got it set up. I drilled a hole through a bolt with a big shoulder on it, that bolts to the throttle and pivots. Then the cable stop clamps down on the cable.
The bike brake barely doesn't have enough throw. I may have to try a different handle.
| Tue Jan 22, 2013 9:46 pm |
duckboy28
i just replaced the original with the bike cable and has not failed me yet! also i crimped the barrel on the end. sure is nice having a bike lever for it way better than a standard throttle
| Tue Jan 22, 2013 10:12 pm |
rob_rides_03
I got the BPS on my stumpjumper. It takes some grinding but I got it on.
| Wed Jan 23, 2013 9:32 am |
Pete
Anyone tried the twist type throttle grip...from Sliphover throttle systems?
| Wed Jan 23, 2013 9:46 am |
SwampDonkey1
| Wed Jan 23, 2013 11:03 am |
Mag10
Joined: Wed Jan 14, 2009 12:31 pm Posts: 342 Location: Faribault, Mn
On my last build, I used a clutch engagement handle from a tiller. It has a bit more travel than a brake lever and was about $25 for the handle and 40" cable.
I will see if I can dig up some pictures.
Mag10
| Wed Jan 23, 2013 12:19 pm |
Cubman
I can't get enough throw out of this bike brake handle. You can adjust it so the motor will idle, or hit WOT, but not both. I am thinking about ordering a BPS handle. Will their cable fit a 23hp Vanguard? How does it attach on the motor end?
| Thu Jul 04, 2013 8:19 pm |
fireman1293
You probably bought a short pull handle. They make a long pull handle too. Buy that one instead.
| Thu Jul 04, 2013 8:36 pm |
Cubman
This is what I got from the local bike shop:
How do I tell if a lever is a long pull? Will this one do the job?
| Thu Jul 04, 2013 9:01 pm |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
Search - lever style throttle , 20$ , 30 minutes .
I put one , clutch style , long throw from local motorcycle shop on my longtail .I listed the part # so anybody could order in the above post , I think it was in feburary. The kind I used would fit the go devil handle with no grinding or adjustments. Works great instant throttle response beats that stock throttle.
H Finn
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
| Thu Jul 04, 2013 11:30 pm |
Cubman
Thanks HF. Somebody welded a section of 7/8" tube into the end of my handle though, so I need something smaller.
| Fri Jul 05, 2013 12:15 am |
SouthernWake
Broke my old throttle yesterday so a bike brake throttle was the plan for the day. Walked into a bike shop bought the cheapest brake lever and cable then put it all together. Total of $15 and 45 min from getting off the couch to completion.
| Sun Jul 07, 2013 4:36 pm |
