It is currently Thu Apr 09, 2026 5:31 pm
[ 6 posts ] |
bfrost12
 23 hp vanny power loss
Losing power when we put the prop in the water. Runs fine outside the water. The motor is falling on its' face when the prop hits the water.
Thoughts?
Thanks!
| Sat Oct 19, 2013 7:52 am |
Broadriverboy
 Re: 23 hp vanny power loss
Clean carb 23 gdlt did the same thing it was the bottom 2 jets clogged out of 4 total
| Sat Oct 19, 2013 9:13 pm |
p5388
Joined: Wed Jul 24, 2013 9:16 pm Posts: 232 Location: Deep East Texas
Also, check your spark plugs, foul 1 and it runs fine unloaded, but won't take a load...
_________________ The key to a successful marriage? Give a man a 4X4 truck, a rifle, a shotgun, a Mud boat, and a fishing pole - he will be out of your hair most of the year...
| Sat Oct 19, 2013 9:38 pm |
Joe Guide
Joined: Mon Nov 02, 2009 7:58 pm Posts: 159 Location: Coastal North Carolina
If it had been making "popping sounds" with severe loss of power, do a leak down test, and you will find it is probably one of the coils...went bad. Better replace both of em when you do.
_________________ Check out "Joe Guide hunting videos" on YOUTUBE...
| Sun Oct 20, 2013 4:10 am |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
Might also want to check on your cavitation plate, if mounted too steep the load applied will sometimes cause the motor to die out. Kinda like killing out a lawn mower by running it through real thick grass too quickly.
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Mon Oct 21, 2013 10:39 am |
Dono
Joined: Tue Feb 05, 2013 8:25 pm Posts: 28 Location: Denham Springs Louisiana
Could be low on oil...I had this problem, and it was the oil level on my dip stik was wrong. I added oil, and that fixed my vacuum.
| Tue Oct 22, 2013 9:38 am |
[ 6 posts ] |
