It is currently Mon Apr 06, 2026 12:28 pm
Reply to topic  [ 30 posts ]
 13 horse honda gx390 build
Post 13 horse honda gx390 build
Finally quit asking questions and researching and started my second build today. going to put a 13 horse Honda gx390 on this one. got some of the transom mount cut and fit up and will start welding when I get more time. Ill post pictures as the progress continues.
Sun Jul 28, 2013 6:42 pm
Post Re: 13 horse honda gx390 build
It looks good so far-what thickness of steel are you using i need to make a transom mount for my build.
Wed Jul 31, 2013 9:20 am
its either 3/16 or1/4" ill measure it tonight. i just started digging around in the scrap pile at the local scrap yard till I found what i thought was enough. im gonna build the transom and motor mount out of the thicker stuff and the skeg and cav plate out of 1/8"
Wed Jul 31, 2013 11:11 am
thanks for the reply and good-luck with the build keep the pictures coming.
Wed Jul 31, 2013 8:47 pm
Finally got a chance to work on the transom mount again today. got it mostly finished up. Going to try to start on the motor mount plate tomorrow night.
Sun Aug 04, 2013 6:37 pm
motor mount plate is finished up.
Thu Aug 08, 2013 8:22 pm
Why is the mount on an angle?
Sent from my DROID RAZR HD using Tapatalk 2
Fri Aug 09, 2013 7:42 pm
It's not on an angle it's just the way it's sitting on the table. If you look at the first set of pictures when the mount is on the boat transom the flat plate is level.
Sat Aug 10, 2013 7:40 am
Oh yeah, I see it now. :lol:
Mon Aug 12, 2013 3:12 pm
finally finished up today.
Sun Sep 15, 2013 8:10 pm
lower seal housing and bushing
Sun Sep 15, 2013 8:16 pm
lower seal housing cap
Sun Sep 15, 2013 8:17 pm
upper seal housing and bearing mount
Sun Sep 15, 2013 8:20 pm
outstanding work you did a great job on your build thanks for posting the pic's-question did you make or buy the seal housing cap.
Sun Sep 15, 2013 8:51 pm
thanks!! everything on this build besides the prop and drive shaft was purchased at either Lowes, home depot, or a local bearing supply house. the seal housings are just 1-1/4' schedule 40 pipe. the main shaft housing is dom tube that is 1" id and 1-3/8" od. the ID of the 1-1/4" sch 40 is 1-3/8" so it slides right over the dom tube. then the seals are 1-3/8 od and 3/4 id so they sit nicely inside the housing. I haven't gotten to run it yet so ill keep you posted but no grease came out of the tube during the 10 or so min I ran it in the shop.
Sun Sep 15, 2013 9:05 pm
sorry just realized you asked about the seal housing cap. I made it out of a 1-1/4" rigid EMT coupler. just cut it in half, welded a piece of plate on the end, drilled the hole for the shaft to go through and sanded it down.
Sun Sep 15, 2013 9:07 pm
what was the approx total cost for complete build?
Mon Sep 16, 2013 2:57 pm
The engine was given to me. I have about 500 dollars in everything else. If you dont buy the shaft premade then you might could save a few more bucks.
Mon Sep 16, 2013 6:50 pm
What size boat are you building this for? I'm building the same setup and having trouble deciding on what size boat I think it can push at a reasonable speed.
Tue Sep 17, 2013 11:27 am
How long is your shaft? :shock:
Tue Sep 17, 2013 11:46 am
Shaft is 72". I would think anything over 15-16 foot 40-42" bottom would be a dog with something as small as a 13 horse. I'm putting this on a 15-42.
Tue Sep 17, 2013 6:56 pm
What size prop are you using and what do you have in between the prop and the seal housing cap? Can you take a picture of the prop end up close with the prop installed? Thanks. Motor looks good.
Wed Sep 18, 2013 1:28 pm
23 swomp/ 1542 tracker
Wed Sep 18, 2013 1:36 pm
His driveshaft probably isn't pushed all the way up into the U joint in that picture.
Wed Sep 18, 2013 4:30 pm
^^^ frank is right. The driveshaft was loose for the earlier pictures. There's probly 3/16 to 1/4 inch between the jam nut and the cap. Prop is an 8x4 from backh2o.
Wed Sep 18, 2013 5:29 pm
Thatsabetter
Wed Sep 18, 2013 5:50 pm
Also good to know that the motor is considered "fukable"... Definitely could be worse!!!
Wed Sep 18, 2013 6:03 pm
Sorry for so many questions, just trying to get an idea of how I'm going to build mine. What is keeping the shaft from pushing into the u-joint?
Wed Sep 18, 2013 7:33 pm
The questions don't bother me I had lots.........short answer is nothing. The u-joint has two hardened set screws that are secured with lock tite so the shaft shouldn't go anywhere. The flange bearing at the top end has 2 set screws but those aren't designed to take any of the thrust load you are talking about. None of the commercial built designs that I'm aware of have anything that takes the thrust load from the prop. I'm sure some kind of special bearing with a thrust collar of sorts could be made to work but these things have been built the same for years with good results. heck the original go devils just had a bronze busing on each end with a couple of seals and I know of several of those things still running around.
Wed Sep 18, 2013 7:44 pm
You can pretty much fuk anything if you put your mind to it.
Wed Sep 18, 2013 7:50 pm
