It is currently Sun Apr 12, 2026 5:36 pm
[ 3 posts ] |
Replacing upper seals on 6.5 lt go devil
TeelGrowney
I have a 6.5 horse 2010 go devil motor that I have been using and am preparing to do an end of summer tune up prior to using it this coming season. As you can see in the pictures attached The upper shaft seal leaks/produces grease once pumped full. In my owners manual all it states is "When lubricating the shaft you are replacing grease lost due to heat expansion, this shouldn't be more than 5 to ten pumps on the grease gun, if consuming more replace the seals". I use my motor on average 3/4 times a month and everything else is in good working condition, and when lubricating before a run it never takes more than 2/3 pumps to fill up the grease reservoir and make the seal ooze grease as shown. It does throw a small amount of grease due to this but i try to keep the seal clean and wiped as much as possible. I'm just not sure if this means i definitely need to replace the seals or if with proper lubrication and care this will last and not cause shaft damage etc. The manual does explain the step by step seal replacement and i can easily buy them and take on the job but this is my first mud motor and I don't want to make the wrong decision. I could always buy them and have a shop replace them but like I said not sure if its necessary/ worth the money. any input is appreciated.
"The Everglades is a test. If we pass it, we may get to keep the planet." - Marjory Stoneman Douglas
| Sun Aug 18, 2013 8:58 pm |
FRANKtheTAU
Joined: Thu Dec 29, 2011 10:30 pm Posts: 1386 Location: West TN
 Re: Replacing upper seals on 6.5 lt go devil
That's what a Go-Devil is supposed to look like! Haha. Seriously though I believe you're fine.
_________________ 40 Backwater SWOMP Lite / 1752 Alweld Mud
| Sun Aug 18, 2013 10:08 pm |
kibb
Joined: Wed Jan 14, 2009 8:58 pm Posts: 2731 Location: Lafayette, LA
That's the cleanest bearing set I've seen yet. You're good.
_________________ 1644 WeldCraft / 27 GDLT Ranger R71 / 125 Merc
| Sun Aug 18, 2013 11:11 pm |
[ 3 posts ] |
