It is currently Mon Apr 06, 2026 6:14 pm
Reply to topic  [ 15 posts ]
 Starting a new build
Post Starting a new build
Hello All
This is my first post.
Been reading for over a year.
I'm about to build a light LT using a 3 HP (79cc) from harbor freight.
Does anyone know of a flange that will bolt to this engine?
If I can get a flange to mate that will go along way towards reinforcing the shaft housing.
I can use a threaded pipe for a housing.
The 4 holes that bolt to the block can be larger than the threaded hole size, I'll use spacers.
This build will be similar to the bolt on no weld kits $399.00 plus S&H.
I appreciate any and all replies to this.
Thanks
Don
Fri Aug 16, 2013 3:15 pm
Post Re: Starting a new build
What kind of flange are you talking about?
Fri Aug 16, 2013 3:28 pm
Like a pipe flange that bolts to the motor where the shaft comes out where a pump would bolt up.
http://www.ebay.com/itm/Enlin-Pipe-Flan ... 5d42dd9776
Fri Aug 16, 2013 3:53 pm
Even a custom or a cast.
This would be a solid starting place to build a shaft housing.
I prefer this to pillar bearings I want to keep it light as pos.
Like this but maybe steel or stanless.
http://www.ebay.com/itm/NEW-BASE-FLANGE ... 19d8cd3fcf
Fri Aug 16, 2013 4:02 pm
Post Engine pump adapter
This is what I'm talking about.
http://www.splitez.com/engine_pump_adapters.html
Engine pump adapter. Except to fit a small 2.5hp-3hp predator engine
Does anyone know the measurements of the bolt pattern for that engine?
I have ordered mine yet.
Fri Aug 16, 2013 4:23 pm
Fab your own "flange" from plate and drill the engine bolt pattern on it then center punch and weld drive tube on. That's how I've seen it done and that's what I run on mine.
Fri Aug 16, 2013 9:29 pm
Post Re: Engine pump adapter
Sat Aug 17, 2013 6:13 am
Found one.
http://www.surpluscenter.com/item.asp?i ... me=engines
Sat Aug 17, 2013 11:00 am
1436 Lowe
Sat Aug 17, 2013 12:24 pm
I plan to connect the engine drive shaft to a 1/2" x 4' shaft by using a a 5/8" shaft arbor.
http://www.ebay.com/itm/Convertible-Mot ... 43be92234c.
This is going on a aluminum 12' sneak boat. Its very light and low to the water.
I'm building this rig for places I can't get to unless I can carry the boat by hand.
I'll also have to be able to easily carry the motor up and down a bank.
I'm trying to keep it as simple and light as possible.
Sat Aug 17, 2013 1:13 pm
Ziton, any updates on this? Did you come out cheaper than the $300 kit?
Sent from my SGH-T999 using Tapatalk 4
Thu Sep 12, 2013 11:26 pm
From what I can tell the light longtails use a coupler like this.
http://www.staffordmfg.com/Search.aspx? ... Mgod1R8AeA
Might be lighter than what you are looking at.
Mudde.
15x42 Duracraft trying hard to stay ahead of a SWOMP 23!
Just a tiny little island of conservatism floating in a sea of liberalism!
"Fathom the hypocrisy of a government that requires every citizen to prove they are insured...., but not everyone must prove they are a citizen."
And now, any of those who refuse, or are unable, to prove they are citizens will receive free insurance paid for by those who are forced to buy insurance because they are citizens". Ben Stein
Fri Sep 13, 2013 8:31 am
I thought that most of them used a chain coupler not the ones in the link
Sent from my iPhone using Tapatalk -
Sat Sep 14, 2013 12:32 pm
The stafford is available as a stepped bored coupler. That eliminates a joint and a purchased part.
and it will give a straighter alignment than the coupler mentioned. Remember you are going to turn it 3,000 rpms. Straighter is better at that rpm.
A chain coupler will be more expensive than the stafford. Lovejoy and beldon also probably make some thing similar if you want to compare prices.
If you have modest alignment issues then a 3 piece lovejoy coupler with the rubber star in the center is a good choice.
Mark F. Cheney
on the Great Salt Lake marsh
Mon Sep 16, 2013 8:32 pm
You can get by with a lot shorter shaft if you use a universal joint. I've built one as well. 5.5 Honda with 55 inch shaft. 87 pounds full of gas.
1542 antique dura craft 16 hp GDLT slow n steady.
Last bumped by brokefarmboy82 on Tue Oct 08, 2013 3:05 pm.
