| Starting a new build http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=44316 |
| Author: | ziton [ Fri Aug 16, 2013 3:15 pm ] |
| Post subject: | Starting a new build |
Hello All This is my first post. Been reading for over a year. I'm about to build a light LT using a 3 HP (79cc) from harbor freight. Does anyone know of a flange that will bolt to this engine? If I can get a flange to mate that will go along way towards reinforcing the shaft housing. I can use a threaded pipe for a housing. The 4 holes that bolt to the block can be larger than the threaded hole size, I'll use spacers. This build will be similar to the bolt on no weld kits $399.00 plus S&H. I appreciate any and all replies to this. Thanks Don |
| Author: | North LA Hunter [ Fri Aug 16, 2013 3:28 pm ] |
| Post subject: | Re: Starting a new build |
What kind of flange are you talking about? |
| Author: | ziton [ Fri Aug 16, 2013 3:53 pm ] |
Like a pipe flange that bolts to the motor where the shaft comes out where a pump would bolt up. http://www.ebay.com/itm/Enlin-Pipe-Flan ... 5d42dd9776 |
| Author: | ziton [ Fri Aug 16, 2013 4:02 pm ] |
Even a custom or a cast. This would be a solid starting place to build a shaft housing. I prefer this to pillar bearings I want to keep it light as pos. Like this but maybe steel or stanless. http://www.ebay.com/itm/NEW-BASE-FLANGE ... 19d8cd3fcf |
| Author: | ziton [ Fri Aug 16, 2013 4:23 pm ] |
| Post subject: | Engine pump adapter |
This is what I'm talking about. http://www.splitez.com/engine_pump_adapters.html Engine pump adapter. Except to fit a small 2.5hp-3hp predator engine Does anyone know the measurements of the bolt pattern for that engine? I have ordered mine yet. |
| Author: | Cajunwannabe [ Fri Aug 16, 2013 9:29 pm ] |
Fab your own "flange" from plate and drill the engine bolt pattern on it then center punch and weld drive tube on. That's how I've seen it done and that's what I run on mine. |
| Author: | p5388 [ Sat Aug 17, 2013 6:13 am ] |
| Post subject: | Re: Engine pump adapter |
| Author: | ziton [ Sat Aug 17, 2013 11:00 am ] |
Found one. http://www.surpluscenter.com/item.asp?i ... me=engines |
| Author: | SwampDonkey1 [ Sat Aug 17, 2013 12:24 pm ] |
| Author: | ziton [ Sat Aug 17, 2013 1:13 pm ] |
I plan to connect the engine drive shaft to a 1/2" x 4' shaft by using a a 5/8" shaft arbor. http://www.ebay.com/itm/Convertible-Mot ... 43be92234c. This is going on a aluminum 12' sneak boat. Its very light and low to the water. I'm building this rig for places I can't get to unless I can carry the boat by hand. I'll also have to be able to easily carry the motor up and down a bank. I'm trying to keep it as simple and light as possible. |
| Author: | birdysportsman [ Thu Sep 12, 2013 11:26 pm ] |
Ziton, any updates on this? Did you come out cheaper than the $300 kit? Sent from my SGH-T999 using Tapatalk 4 |
| Author: | muddewatrs [ Fri Sep 13, 2013 8:31 am ] |
From what I can tell the light longtails use a coupler like this. http://www.staffordmfg.com/Search.aspx? ... Mgod1R8AeA Might be lighter than what you are looking at. Mudde. |
| Author: | DrahthaaRunner [ Sat Sep 14, 2013 12:32 pm ] |
I thought that most of them used a chain coupler not the ones in the link Sent from my iPhone using Tapatalk - |
| Author: | Mark F. Cheney [ Mon Sep 16, 2013 8:32 pm ] |
The stafford is available as a stepped bored coupler. That eliminates a joint and a purchased part. and it will give a straighter alignment than the coupler mentioned. Remember you are going to turn it 3,000 rpms. Straighter is better at that rpm. A chain coupler will be more expensive than the stafford. Lovejoy and beldon also probably make some thing similar if you want to compare prices. If you have modest alignment issues then a 3 piece lovejoy coupler with the rubber star in the center is a good choice. Mark F. Cheney |
| Author: | brokefarmboy82 [ Tue Oct 08, 2013 3:05 pm ] |
You can get by with a lot shorter shaft if you use a universal joint. I've built one as well. 5.5 Honda with 55 inch shaft. 87 pounds full of gas. |
