It is currently Wed Jul 16, 2025 7:41 pm
[ 7 posts ] |
Tall Transom LT on Short Transom Boat
cbrdux
Any issues with this setup? Anyone run it? Any problems? Good, Bad, Fugly??? Running a 1650 Flat Bottom Jon.
Mon Sep 07, 2009 8:39 pm |
Tenpoint
Joined: Thu Aug 27, 2009 5:22 pm Posts: 2029 Location: Patterson LA
 Re: Tall Transom LT on Short Transom Boat
Not sure what you mean by a tall transom LT. Long tails come in something like a 76" or a 52" shaft. The shorter being what they call the crawfish model. They are both designed for a short transom.
_________________ 19x48 Rink/Aucoin Bateau w/35 GTR 20x60 Home-made skiff w/200 Merc
Tue Sep 08, 2009 6:23 pm |
cbrdux
To clarify.......... Looking at buying a longtail with an 85" outdrive.. This is designed for a transom height up to 21". My transom is 16"...(so an outdrive at 72" is recommended) I've talked with several people who tell me that using this setup is OK. it just pushes the boat flatter, since the length of the tail sits deeper in the water. I'm looking for input from guys who may have used a setup similar to what I am considering... Hope that helps....
Tue Sep 08, 2009 8:09 pm |
harbday
Joined: Wed Jan 14, 2009 8:52 pm Posts: 37 Location: Tallahassee, FL
i have this setup and it works great. the guys at MB said it actually gives the boat more pop out of the hole shot in the shallow stuff. go for it.
_________________ 1648 w/ 27LT Go Gators
Tue Sep 08, 2009 9:55 pm |
burdman42
Joined: Sun Jul 05, 2009 8:19 pm Posts: 1 Location: Kansas City, Mo
I used this setup for a while and then I built my transom up another 4 inches. You will not lack any performance, but on some boats you will not be able to get the prop out of the water or all the way up depending on if you have built in seats in your jon boat or not.
Wed Sep 09, 2009 4:04 pm |
Tenpoint
Wed Sep 09, 2009 4:15 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
You should actually get a flatter push from it, if it's the other way around the motor will push upwards too much, causing the boat to nose dive a little and you will lose speed.
_________________ Put yer face in the myrtles.
Sun Sep 13, 2009 7:26 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 62 guests |
