It is currently Mon Apr 06, 2026 5:37 pm
[ 5 posts ] |
set-up question for 14'/13hp
MSpolarich
New Member
Questions for the experts from a rookie
A friend of mine has a 1442 Alumacraft with a 15" transom and 20" sides. He has a Beavertail with a Honda GX390 motor that is supposed to get 13hp @ 3400 RPM and 18 lbs of torque with a 8X4 prop, year of manufacture around 2008. What speed should he be getting from this combination? Right now he feels like a decent headwind will stop any forward movement. He plans on installing a tach to see if he is running in the correct RPM range.
Any advice on things to check for better performance?
(edited: I had the make of the longtail wrong, its a Beavertail)
| Wed Sep 11, 2013 11:08 am |
ruckup
Joined: Wed Aug 08, 2012 11:03 am Posts: 35 Location: Alaska
 Re: set-up question for 14'/13hp
I have a homebuilt LT powered with a Honda GX340 on a 16x48 and it will push me my daughter and my dog along through the lake at 14mph. With a full hunting load it does slow me down significatly but I was still able to push up a strong current under full load 400lb+ at about 5mph. Checking the RPMs is the first place to start IMO. Maybe the throttle or governer is not adjusted properly. Be aware this is comming from a novice not a expert, but it is what I experienced also. Good luck.
| Wed Sep 11, 2013 11:40 am |
Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
1542 with Honda 390. I had a set up with no universal joint so I believe it was 13 hp. I was getting 13 mph. That was 2 guys,dog and decoys. That was a Thailand setup
_________________ 23 swomp/ 1542 tracker
| Wed Sep 11, 2013 1:11 pm |
MSpolarich
New Member
Thanks for the feedback guys. We will see what the tach shows and maybe GPS it to check the speed.
| Thu Sep 12, 2013 5:06 am |
ottertailriverrunner
Joined: Fri Oct 02, 2009 4:46 pm Posts: 79 Location: Otter Tail County, MN
I ran the same motor on a gdlt and a alumacraft 1448 rivited. Got about 14mph with no load. Went downhill real fast with any load at all. I now run a 20 honda on the same boat and will get 17-18 and it will carry a load much better.
| Sun Oct 06, 2013 8:00 am |
[ 5 posts ] |
