| set-up question for 14'/13hp http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=45273 |
| Author: | MSpolarich [ Wed Sep 11, 2013 11:08 am ] |
| Post subject: | set-up question for 14'/13hp |
Questions for the experts from a rookie A friend of mine has a 1442 Alumacraft with a 15" transom and 20" sides. He has a Beavertail with a Honda GX390 motor that is supposed to get 13hp @ 3400 RPM and 18 lbs of torque with a 8X4 prop, year of manufacture around 2008. What speed should he be getting from this combination? Right now he feels like a decent headwind will stop any forward movement. He plans on installing a tach to see if he is running in the correct RPM range. Any advice on things to check for better performance? (edited: I had the make of the longtail wrong, its a Beavertail) |
| Author: | ruckup [ Wed Sep 11, 2013 11:40 am ] |
| Post subject: | Re: set-up question for 14'/13hp |
I have a homebuilt LT powered with a Honda GX340 on a 16x48 and it will push me my daughter and my dog along through the lake at 14mph. With a full hunting load it does slow me down significatly but I was still able to push up a strong current under full load 400lb+ at about 5mph. Checking the RPMs is the first place to start IMO. Maybe the throttle or governer is not adjusted properly. Be aware this is comming from a novice not a expert, but it is what I experienced also. Good luck. |
| Author: | Trousertrout [ Wed Sep 11, 2013 1:11 pm ] |
1542 with Honda 390. I had a set up with no universal joint so I believe it was 13 hp. I was getting 13 mph. That was 2 guys,dog and decoys. That was a Thailand setup |
| Author: | MSpolarich [ Thu Sep 12, 2013 5:06 am ] |
Thanks for the feedback guys. We will see what the tach shows and maybe GPS it to check the speed. |
| Author: | ottertailriverrunner [ Sun Oct 06, 2013 8:00 am ] |
I ran the same motor on a gdlt and a alumacraft 1448 rivited. Got about 14mph with no load. Went downhill real fast with any load at all. I now run a 20 honda on the same boat and will get 17-18 and it will carry a load much better. |
