It is currently Tue Apr 07, 2026 9:09 am
Reply to topic  [ 3 posts ]
 23 hp Vanguard Long Tail
Post 23 hp Vanguard Long Tail
Last season I had my boat out and as I was heading back to the dock, in the dark, and I started losing power and heard a "tick." The ticking increased with the RPM's. Checked the oil when I got back and it was full.
I have had it running on the stand in the garage and it didn't seem to do it. Haven't had it on the water yet but I'm a little nervous that under a load it may come back.
Any thoughts?
Thanks in advance!
Mon Oct 14, 2013 7:44 pm
Post Re: 23 hp Vanguard Long Tail
not sure about the tick but for loss in power, what do you have for your gas line connections. Start at your fuel tank and work your way back checking your connects. I ran into a very similar problem when I used quick connect. Only ran bad when under a load, ran fine out of the water.
Burlap Brothers
Wed Oct 16, 2013 12:47 pm
Don't know of about the loss of power but mine makes some crazy noises from the prop loosening and tightening on the shaft
23 swomp/ 1542 tracker
Wed Oct 16, 2013 12:59 pm
