It is currently Sat Apr 11, 2026 1:55 pm
Reply to topic  [ 6 posts ]
 23 hp vanny power loss
Post 23 hp vanny power loss
Losing power when we put the prop in the water. Runs fine outside the water. The motor is falling on its' face when the prop hits the water.
Thoughts?
Thanks!
Sat Oct 19, 2013 7:52 am
Post Re: 23 hp vanny power loss
Clean carb 23 gdlt did the same thing it was the bottom 2 jets clogged out of 4 total
Sat Oct 19, 2013 9:13 pm
Also, check your spark plugs, foul 1 and it runs fine unloaded, but won't take a load...
Sat Oct 19, 2013 9:38 pm
If it had been making "popping sounds" with severe loss of power, do a leak down test, and you will find it is probably one of the coils...went bad. Better replace both of em when you do.
Check out "Joe Guide hunting videos" on YOUTUBE...
Sun Oct 20, 2013 4:10 am
Might also want to check on your cavitation plate, if mounted too steep the load applied will sometimes cause the motor to die out. Kinda like killing out a lawn mower by running it through real thick grass too quickly.
1436 Lowe
Mon Oct 21, 2013 10:39 am
Could be low on oil...I had this problem, and it was the oil level on my dip stik was wrong. I added oil, and that fixed my vacuum.
Tue Oct 22, 2013 9:38 am
