It is currently Wed Apr 08, 2026 8:56 pm
Reply to topic  [ 11 posts ]
 Water in shaft housing?
Post Water in shaft housing?
Ugh!! Have water somehow getting into my shaft housing 23 HP vanguard GD no play in the prop so I assume the bushing is good.
16' skiff 23 GDLT
Tue Nov 12, 2013 5:03 pm
Post Re: Water in shaft housing?
Lower seals ?
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Tue Nov 12, 2013 5:22 pm
Lower seals being bad is about the only way that's possible.... Unless you have somehow mounted your motor to the bottom of the boat instead of the top lol
Tue Nov 12, 2013 6:51 pm
Clean the grass from in between the nut and seal housing after every trip. That shit dries out like rope and eats seals.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Tue Nov 12, 2013 7:18 pm
Tue Nov 12, 2013 8:20 pm
Is it a grease seal or an oil seal?
16' skiff 23 GDLT
Thu Nov 14, 2013 7:22 pm
Grease seal
Thu Nov 14, 2013 7:30 pm
FYI, old style is two seals back to back. New style is two seals back to back and a scraper seal. Scraper seal is closest to the prop and the side with writing faces the engine.
Thu Nov 14, 2013 10:02 pm
Thank you all! I believe it is a newer style. I could more than likely get the grease seals from Napa? I would just order them from GD but I need to get this resolved this weekend.,
16' skiff 23 GDLT
Thu Nov 14, 2013 10:46 pm
You may find something that will get you by, but I believe the ones from GD are a proprietary design that's manufactured for them.
Thu Nov 14, 2013 11:08 pm
In addition to Kibb...How do you store your motor? If you store it outside and uncovered, you could have water intrusion from the top near the universal joint. Unlikely, but I would check to rule it out.
Sun Nov 17, 2013 7:14 am
