supercajun
 go devil seals
Where can I get seals for a 9hp go devil? I know you can call go devil with a serial number but this frame dosent have one. The frame was my grandpaws and he told me he bought it from them 20plus years ago. I put my caliper on the bushings and got those locally but can't find seals.
| Mon Oct 28, 2013 10:57 am |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
 Re: go devil seals
My 9 hp GD I bought 20 years ago had the serial number stamped into the frame. Call GD and tell them what you have. Bet they will help you out.
| Mon Oct 28, 2013 11:03 am |
shooter
 Re: go devil seals
I found a brand new set of seals in my cabinet, bought them for my 25 longtail but never used them. Any chance they're the same seals? If so, you can have 'em.
Send me some dimensions on what you've got.
_________________ 32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
| Mon Oct 28, 2013 1:15 pm |
Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
 Re: go devil seals
^^^^ you are a mans man. My wife would never allow me to keep mm parts in the kitchen cabinets
_________________ 23 swomp/ 1542 tracker
| Mon Oct 28, 2013 2:31 pm |
supercajun
 Re: go devil seals
| Mon Oct 28, 2013 5:36 pm |
shooter
 Re: go devil seals
Damn, these are for a 3/4" shaft. Sorry.
| Tue Oct 29, 2013 10:21 am |
poke_chop666
Joined: Sat Apr 06, 2013 12:07 am Posts: 487 Location: port barre,la
 Re: go devil seals
Shooter whrre you from? Is that upper or lower seals? Ill buy my own but do u have a part number I can try to get mine locally
_________________ 25 yamaha pushing a 1642 welded flat 20 hp go-devil longtail for hunting.
| Mon Nov 25, 2013 10:23 am |
shooter
 Re: go devil seals
| Mon Nov 25, 2013 5:27 pm |
poke_chop666
 Re: go devil seals
Whos coco? Im just trying to get a part number to cross referrence
| Mon Nov 25, 2013 8:27 pm |
kibb
 Re: go devil seals
The guy who owns Go-Devil.
| Mon Nov 25, 2013 8:38 pm |
kibb
 Re: go devil seals
| Mon Nov 25, 2013 8:41 pm |
swamp_fox
Joined: Tue Oct 08, 2013 5:39 pm Posts: 265 Location: St.Amant, LA
 Re: go devil seals
Yep, call go-devil. Those shouldn't have changed much through the years.
_________________ 17'Extreme Metal Fab. Skiff - 23 GDLT
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
 Re: go devil seals
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
| Mon Nov 25, 2013 9:55 pm |
poke_chop666
 Re: go devil seals
Go devil wont give me a part number. I was gonna go 5o OReilly or something and try to get it
| Tue Nov 26, 2013 8:01 am |
kibb
 Re: go devil seals
They won't give anything if you don't have a serial number.
| Tue Nov 26, 2013 8:13 am |
shooter
 Re: go devil seals
OK, I've got a bag of 3/4" seals that I labeled Go-Devil shaft seals (wrong ones) that have the following markings on them: TAIWAN TOM 075112 TOY. I got these from GD but they weren't the ones I had ordered.
I also have a bag of 3/4" seals I labeled #4B Lower Seals, P/N 20810-LPDW.
That's all I know about them. You can have them if they'll help you.
| Tue Nov 26, 2013 9:59 am |
poke_chop666
 Re: go devil seals
I had serial number and all and she was like all I can tell you is our part number which is 7 lol.
| Wed Nov 27, 2013 6:45 am |
kibb
 Re: go devil seals
I'm pretty sure the seals are proprietary. I think they have someone make the seals just for them.
| Wed Nov 27, 2013 7:51 am |
Mark F. Cheney
Joined: Sat Mar 07, 2009 9:44 am Posts: 154 Location: Bountiful, Utah
 Re: go devil seals
seals are simple. Get an SKF seal book from Kaman and match up your ID, OD, and lip construction and you will be set to go. They really arn't very expensive.
Mark F. Cheney
_________________ on the Great Salt Lake marsh
| Thu Dec 12, 2013 11:35 pm |
shooter
 Re: go devil seals
Thanks for the tip! SKF actually has android and iPhone apps for both seals and bearings.
| Fri Dec 13, 2013 12:02 am |
