It is currently Mon Apr 13, 2026 10:20 am
[ 6 posts ] |
jeff cox
Joined: Thu Jan 13, 2011 7:48 pm Posts: 20 Location: Chana IL.
 Long tail gear reduction
Hi guys I'm wanting to start a new L T build in spring been thinking of putting a clutch on it so I had a few questions hoping you guys could give me some answers . do you use a lawn mower clutch ? how do you hook drive shaft up use a jack shaft of some kind ? do you change angle of shaft if using jack shaft and is it worth it thank you very much have learned a lot off this site Jeff
_________________ Chanaboy
| Thu Dec 26, 2013 6:47 pm |
Mark F. Cheney
Joined: Sat Mar 07, 2009 9:44 am Posts: 154 Location: Bountiful, Utah
 Re: Long tail gear reduction
I think that it is way simpler to put a drive shaft reduction on a long tail than to build a short tail surface drive with its complicated transom mount.
On my 7 HP models I am using a chain driven reduction with a wet clutch. I am hooking the UJ to the gear box PTO with no external jack shaft. There are good industrial centrifugal clutches out there that would work with a jack shaft as well.
For my larger motors I use a centrifugal clutch and a jack shaft and then put in my regular compound UJ to the drive shaft. So far on my 14 HP motor I have used a BX belt from the clutch to the jack shaft.
Mark F. Cheney
_________________ on the Great Salt Lake marsh
| Sat Dec 28, 2013 10:18 pm |
jeff cox
Thank you Mark at least that gives a starting point to think about
| Sun Dec 29, 2013 3:30 pm |
brianb
Joined: Mon Nov 29, 2010 6:02 pm Posts: 534 Location: louisiana
Mark please post some pics of your setups
_________________ gtr35 gt 1854 / w gatorglide 12 ft 11hp longtail 14 ft 10 hp longtail Merc 225hp TR20
| Sun Dec 29, 2013 6:18 pm |
Cajunwannabe
Joined: Wed Jan 28, 2009 3:40 pm Posts: 188 Location: Wishing I was in SE La.
I'd like to see what exactly a jack shaft is too.
I'd love to try a light 14 hp motor too Mark. My 25 hp gets the job don but it's a beast to drive. lol
| Sun Dec 29, 2013 8:20 pm |
Mark F. Cheney
If this is any help - a 25 hp straight long tail turns a 9 x 7 prop. a 14 HP long tail with a 1 1/2 to 1 reduction thru a clutch and a jack shaft turns a 10 x 8 prop. I am working on some pictures now.
Mark F. Cheney
| Mon Dec 30, 2013 7:43 am |
[ 6 posts ] |
