It is currently Mon Apr 13, 2026 8:40 am
[ 6 posts ] |
poke_chop666
Joined: Sat Apr 06, 2013 12:07 am Posts: 487 Location: port barre,la
 20 hp loss compression
Hunted saturday and my go devil ran like a dream. Sunday I launched and it wouldnt start. Got it started for like 2 min and died and never started again. Normally the compression is so hard that if u pull in the wrong spot it will rip ur arm off. Sunday I could pull and pull with no kick back. Anything I should check first thats easy before I completely rebuild the engine?
_________________ 25 yamaha pushing a 1642 welded flat 20 hp go-devil longtail for hunting.
| Mon Dec 23, 2013 11:53 pm |
poke_chop666
 Re: 20 hp loss compression
20 horse vanguard is what it is.
Joel907
Check the valves sounds like rockers they just need adjusting.
| Tue Dec 24, 2013 7:34 am |
poke_chop666
I figured I might have broke a valve spring or something. Gonna check it out
| Tue Dec 24, 2013 10:50 am |
poke_chop666
Found out a pushrod had come off the rocker arm. What could be the causes of this? Does it just happen some time?
| Thu Dec 26, 2013 3:10 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
Loose rocker studs will cause it...not sure what else.
| Thu Dec 26, 2013 3:31 pm |
[ 6 posts ] |
