n.o.yat
Joined: Wed Jan 14, 2009 10:24 am Posts: 134 Location: ponchatoula la.
 turning a longtail
my son gave me a longtail. i put a new motor on it and put it on a 16x44 go devil duck skiff. my question is , what is the easiest way to make it turn.going around a turn is ok, but trying to spin it around takes a lot of room. any ideas, thanks.
| Mon Oct 12, 2009 6:45 am |
bbb
Joined: Wed Sep 02, 2009 2:54 pm Posts: 1554 Location: SW Georgia
 Re: turning a longtail
Ain't no easy way especially if you have a boat the slides.
My previous boats rear end slid and when stopped, trying to turn around, it still slid.
My current boat turns on a dime and I can sit at idle and turn circles.
Also, if you have alot of weight towards the front of the boat it will not spin well.
_________________ 19x54 Seminole Extreme with a 35hp CDI GDSD. Mikuni. Marsh Mellow. Heads. Cam.
| Mon Oct 12, 2009 7:11 am |
lparrish
I start into the turn pretty sharp then lift the tail out of the water. The back of the boat will continue to spin around, once the boat is pointing in the direction I want to go I drop the tail. You have to think ahead and know what you are going to do before you start the turn.
| Mon Oct 12, 2009 7:25 am |
earl33
Joined: Wed Sep 16, 2009 3:47 pm Posts: 2261 Location: West Tennessee
Your not going to spin it around running fast. If your looking to change direction say on a small river, Running at idle speed start your turn then pull the prop out of the water, the momentum will bring the stern around. You may have to do this a time or two.. Use the long tail like a paddle and rudder. It takes some practice.
_________________ If the Steel aint Flying the Birds aint Dying.... Uncle J 1948 holding a LT Uncle J 1848 w/?
| Mon Oct 12, 2009 7:36 am |
lparrish
Your right earl33. I did not mean to try that maneuver running fast. The first thing would be to slow down, and I also use the tail as a paddle to help the boat come on around.
| Mon Oct 12, 2009 7:44 am |
earl33
lparrish PM sent...
| Mon Oct 12, 2009 7:51 am |
n.o.yat
i am pretty much talking about if i were stopped in a small river and wanted to spin around in another direction. i also have a prodrive and all i do is hit the momentary button a couple of times and it spins around easily.
| Mon Oct 12, 2009 9:13 am |
Wendlwacker
stick time stick time stick time and you will learn some neat little tricks!
| Mon Oct 12, 2009 9:27 am |
n.o.yat
oh yeah, plan on doing some riding this weekend.
| Mon Oct 12, 2009 9:45 am |
Da-Cajun-Angla
u HAVE to have it trimmed right. mine was soooo hard to turn until i adjusted the trim. the cav plate should run righ under the water.
_________________ cajun: its real simple, we live back hea', dis' is our home, an' nobody don' fuk wit' us!
| Mon Oct 12, 2009 10:10 am |
