It is currently Mon Apr 13, 2026 9:43 am
Reply to topic  [ 6 posts ]
 20 hp Longtail vs 24 hp speeds
Post 20 hp Longtail vs 24 hp speeds
Just sold my 20 hp Longtail that I ran on a 1642 custom flat
Thinking about but a 24 hp Longtail I just found but wondering about speeds. My 20 hp did 19-20 MPhil with em and 17-18 with me and one person. How big of a difference am I looking at in speed?
25 yamaha pushing a 1642 welded flat
20 hp go-devil longtail for hunting
Sat Jun 21, 2014 10:26 pm
Post Re: 20 hp Longtail vs 24 hp speeds
I will venture to say, all things being the same, you might obtain an additional 2-3 mph more. A variable there might be the prop size, you should be able to spin a 9x6 but it will be trial and error. Is that a Honda 24? My friend had one that was a lemon and others had trouble with their units but otherwise a solid powerplant. You can certainly run a 25/ 27 Kohler LT on that 1642. In mud and weeds you will have more torque and push with that 24. The 23 Briggs is a good compromise and that usually comes with recoil start and electric, and that motor can be modded up. As others on this forum have stated, I will also recommend a BackH20 motor over the other mfg.'s.
Sun Jun 22, 2014 5:39 am
Yes it is the honda. I'm only working with 1500 right now so I'm limited but may wait and see what else I can find
Sun Jun 22, 2014 11:02 am
That 24 is a fine motor. Havent met one yet that doesnt have more than 1000 hours. We ran one for 15+ years, its got another 3 on it since we sold it. Had to redo the shaft and seals/bearings once, and it's had a few props, but the motor is still going. Id recommend that honda without hesitation.
Sun Jun 22, 2014 6:19 pm
You might get another mph or two, but you'll def get more umph at lower rpms.
Sun Jun 22, 2014 6:20 pm
Im with Russ - probably wont pick up much speed but be able to carry a load a little better and be better at digging out of stuff. I picked up an 02 mblt with the 24 a couple years ago and have been real happy with it. Woodiebuster on here also has one.
Wed Jun 25, 2014 9:16 am
